One other thing comes to mind. If you have both zones set to 72 and both zones are set to Mode=Cool and Fan=Auto, the bedroom temperature may be at 72 degrees or cooler and will only turn on once the temperature goes above 72.
I always set zone 1 to Mode=Cool, and Fan=Auto.
I always set zone 2 to Mode=Cool, and Fan=High at night because we like the fan noise to sleep. It helps to drown any noise outside the camper plus we can't sleep without fan noise.
What is the outside temperature when the inside Zone 1 temperature is 79 and set to 72?
Either 1 of the units in Zone 1 has an issue, is wired wrong, or the outside temperature is above 100 degrees and you are in full sun in a really dry climate.
Have you taken the lids off the outside units to make sure the fins are not clogged? Watch out, wasps love these areas.
Inside filters clean?
Curious to find out what you find out.
Good luck!
2017 Cedar Creek Champagne 38EL
2020 Silverado 3500 SRW High Country
