High heat caused us serious trouble recently in Utah when the mylar tape liner in the squirrel cage fan surround came lose and became confetti in the trailer! The 110+ degree temps must have done the trick. We shut it down until I could reach up from below and pull the mylar out of the fan surround.
However, this Coleman Mach 3 unit has never worked like I think it should. The dial on it says it has HI and LO fan speeds as well as HI and LO cooling, but you'd be hard pressed to tell the difference between HI and LO for fan or A/C. Gotta wonder if the person who installed it got the wiring harness connected properly. Anyone else have this problem or a resolution to it?
