Old 01-15-2019, 05:06 PM   #1
Boatdude62's Avatar
Adding extra stability to 40 CC 6point level system.
Any advice on add straps or extra support to 40 camper on 6 point leveling system? I have the camper as low as possible on the level system, but we are still getting allot of wobble inside. And even feel it in moderate winds.
In Florida sandy type grass....jacks are on solid concrete 8 risers blocks.
Im thinking of adding opposing straps at the rear frame.
Anyone experimented with this concept?
Boatdude62 is offline   Reply With Quote
Old 01-15-2019, 06:12 PM   #2
MagnoliaTom's Avatar
Do you have JT strongarms or steadyfast stabilizers? They work well to reduce the shake
2014 Freedom Express 320BHDS Liberty Edition 50th Anniversary
2005 F250 Lariat SuperCrew 6.0 PS Diesel
2004 Excursion Limited 4x4 6.0 PS Diesel
2000 Excursion Limited 7.3 PS Diesel Sold:crying
MagnoliaTom is offline   Reply With Quote
Old 01-15-2019, 06:24 PM   #3
Always Learning
Agreed, add the SteadyFast system.
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
ependydad is online now   Reply With Quote
Old 01-15-2019, 07:15 PM   #4
dieselguy's Avatar
We also had noticeable "wobble" with the Lippert Level Up 6 point levelers no matter how little we extended the cylinders. Our fiver is shorter than yours at 37', but there is still a lot of camper hanging in the air behind the rear jacks. I added the rear electric stabilizer jacks that used to come on fivers before the Level Up System and it cured the "wobble". Here's an example of what I'm talking about … there are other vendors and other brands.
https://www.etrailer.com/Camper-Jack...caArWGEALw_wcB
dieselguy is offline   Reply With Quote
Old 01-15-2019, 08:42 PM   #5
wls
I saw a redwood owner at Shipshewana campground have a A-Frame jack mounted in his rear hitch. He said it made a big difference. He would just crank it down to snug.
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2
2016 Camping Days=38
2017 Camping Days=24
wls is offline   Reply With Quote
Old 01-15-2019, 10:44 PM   #6
florabama's Avatar
I'm using these on the landing gear and I don't have any wobble. Not sure I had much even before I started using these.
ID:	194685   Click image for larger version
2016 Ram 3500HD 6.7L CTD 4x4 CCSB
2017 CC 34RL2 Hathaway Edition
Andersen Ultimate 5th Wheel Hitch
Nights Camped: 2017=61
Nights Camped: 2018=25
Nights Camped: 2019=12 | Booked=6
florabama is offline   Reply With Quote
Old 01-16-2019, 08:47 AM   #7
wmbuttion's Avatar
CC38RD owner. Have 12 ft. behind rear hydraulic jacks. Had alot of shaking until this fix. Found 5,000 pd. scissors jacks at a yard sale. Mounted them on the I beam as far back as possible. Problem fixedClick image for larger version
wmbuttion is offline   Reply With Quote
Old 01-16-2019, 04:02 PM   #8
Can you tell me what company makes these? I would be interested in purchasing some myself.
Thanks!
DwaneHalstead is offline   Reply With Quote
Old 01-16-2019, 04:15 PM   #9
Thanks!
BAL makes the ones in the photo wmbuttion posted.
Similar jacks are available many places, even Harbor Freight.
BAL Scissor Jack
Harbor Freight Scissor Jack (1.5 Ton)
Harbor Freight Scissor Jack (2.5 Ton)
Days Camped: '18=51 '19=58 '20=110 '21=94
Old 01-16-2019, 04:56 PM   #10
Canadian Member
Thanks!
https://andersenhitches.com/Products...ck-6-pack.aspx
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 01-16-2019, 05:47 PM   #11
Amazon
Thanks!
Amazon has three or four different brands. I just happened to meet another camper who had ordered two and discovered he didn't need them. He offered to sell the pair to me for $40 and I jumped at it.
Larry
Larry-NC is offline   Reply With Quote
Old 01-16-2019, 05:57 PM   #12
Larry
Thank you
Old 01-18-2019, 08:02 PM   #13
dieselguy's Avatar
The red Anderson Jack Blocks do work to some extent, but assuming you have 6 for a Level Up System … they'll take up the equivalent of two 5 gallon plastic buckets of storage space unless you have room to stack them more than 3 high which I don't. They will also sink in soft ground as the bottom is not a solid surface. You'd just have to turn one upside down to see what I mean.
Old 01-19-2019, 11:32 AM   #14
Those Anderson blocks look really cool until you look at the price!
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 01-19-2019, 11:54 AM   #15
dieselguy's Avatar
Yeah … pricey!! As supported a few replies prior, some people like them and say they work. Just not for me for the reasons I already covered. Some people trying them with Level Up have had issue with the Andersons when on an unlevel campsite … they won't let the RV nose down enough before the cylinder bottoms out, so the level sequence faults out. Others have had issue with the magnets coming off or the bucket rim that contacts the ground cracking off. All in all as with many innovative products … some people like them … others are disappointed in the flaws. It's your call.
Old 01-19-2019, 02:28 PM   #16
sh1pper's Avatar
United RV in Ft Worth has the best price I've found. Everyone else seems to sell them at MSRP.
Hugh and Fran
"Riley" the dog
2018 Cedar Creek 38EL Champagne
2017 Ford F350 SRW CC SWB 4x2
Demco Hijacker Autoslide 18k Hitch
sh1pper is offline   Reply With Quote
