Old 01-30-2023, 02:20 PM   #1
WanderingDennis's Avatar
Aqua View Showermiser Shower Water Saver
Cedar Creek and Hathaway owners!
Anyone installed the Aqua View Showermiser Shower Water Saver?
How do you access the back of the shower? I don't see any way through the hall closet. Can it be done from the shower side?
https://tweetys.com/aqua-view-smb001-shower-water-saver.aspx?utm_term=&utm_campaign=&utm_source=adwo rds&utm_medium=ppc&hsa_ver=3&hsa_kw=&hsa_cam=17058 388696&hsa_acc=1425045090&hsa_tgt=&hsa_ad=&hsa_net =adwords&hsa_grp=&hsa_src=x&hsa_mt=&gclid=CjwKCAjw h-CVBhB8EiwAjFEPGQbT2NkhzQd_uM_moPqEZLMotg70RNgImfLq 6v-_F-VasQ8-QV7vaBoCGwwQAvD_BwE
WanderingDennis is offline   Reply With Quote
Old 01-30-2023, 03:14 PM   #2
bikendan's Avatar
Moved thread from the Modifications and Updates section to the Cedar Creek sub-forum since the OP is asking for feedback from owners of Cedar Creek products.
Old 01-30-2023, 06:36 PM   #3
dieselguy's Avatar
Can't answer your question, but I can offer a thought on actual savings verses install headaches. Most RV's showers are very near the HW heater. My last 3 fivers took maybe 4-5 seconds to get hot water to the shower ... catch that in a cup and brush your teeth with it. We use an Oxygenics 26481 shower head that does a good job of getting you wet without much water.
dieselguy is offline   Reply With Quote
Old 01-30-2023, 07:00 PM   #4
Your (OP's) profile, signature, or post do not show your model #, so people cannot know your unit's floor plan.
I installed my own self designed version of a shower miser in my motorhome. Perhaps, if I knew your layout, I might be able to suggest a course of action.
I found the "shower miser" to be very valuable as the water heater was a long way away from the shower.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 01-30-2023, 09:14 PM   #5
bikendan's Avatar
Apparently the OP has a 2020 CC Hathaway 34IK.
Old 03-16-2023, 03:18 PM   #6
Yes it can be done. Pull the fan switch cover and the switch itself to view shower faucet cut out. All work can be don through this opening.
Rv Wizard is offline   Reply With Quote
Old 03-16-2023, 03:19 PM   #7
The switch is in the coat closet.
Old 03-16-2023, 03:23 PM   #8
On my Hathaway 34 RL2 I would have to layout the hole to the right of the faucets if I was standing in the shower. Trying to go to the left will run you into the closet.
Old 03-16-2023, 05:40 PM   #9
I tried to send a picture that I took through the fan light switch but I wasn’t sure how to do it. Hope this will let you decide on whether or not to do the upgrade.
Old 03-16-2023, 05:47 PM   #10
Mr. Dan's Avatar
Open your recently received Welcome PM, click on the link to Forums 101, follow instructions in post #7 for posting pics.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 135; Booked for 2023 = 28
Old 03-16-2023, 07:39 PM   #11
Shower picture
Hope this works.
Old 03-16-2023, 07:40 PM   #12
Thanks for the help Mr Dan.
Old 03-16-2023, 09:07 PM   #13
Picture came through fine. Will open the fan switch tomorrow and take a look.
Thanks Rv Wizard
Old 03-16-2023, 09:10 PM   #14
Still can not figure out why they decided to put the fan switch in the closet.
Old 03-18-2023, 09:24 AM   #15
A previous message I sent may have been a little misleading, so let me explain. Looking through the fan switch opening will just let you see the back side of your shower faucet cut out and what’s directly behind it. If everything looks ok you would have follow the procedure for marking the drill hole and then remove your shower faucet panel and do all the work through that opening. I would drill the hole put the Aqua View drain line through the hole making sure to properly caulk it. Then install the gasket and locking ring on the inside of the wall and carefully tighten it up. If your shower line connects to the top of your faucet (like mine)I would leave the Aqua View valve so it’s just about 1/4” higher than its final tightened position. Now put a section of drain line in that can reach to where you going to send it back to the fresh water holding tank. Make sure you put the connection onto the end of this line that is going to connect to the Aqua View (inside the wall) before you run the line. Next connect it to the Aqua View. VERY IMPORTANT…..Make sure that you replace the rubber seals in the hot and cold water lines before reconnecting them to the valves otherwise you risk a leak (they are very cheap). Caulk the valve panel and reinstall it. Now gently rotate the Aqua View down the 1/4” and connect it to the valve and connect it to the faucet connection. Reconnect the shower line and then finish by tying in your drain line. This assumes your shower line connects to the top of your rvs faucet and if it comes in on the bottom you will have to adjust a few things.
Old 03-18-2023, 10:02 AM   #16
Hope this helps clear things up.
Old 03-18-2023, 02:58 PM   #17
Now, If only I could find one for sale
Old 03-18-2023, 04:07 PM   #18
I believe that both Rockwood and Flagstaff are installing these units right at the factory. My friend has had them in his last two trailers. In the newer trailers they run the return right out through the shower valve panel so they don’t have to drill the shower wall. This makes things much simpler because I’m sure they get the panel premolded with the hole for the Aqua View.
Old 03-18-2023, 04:53 PM   #19
Here’s a picture of the Aqua View that goes through the panel in some new trailers.
show, shower, water
