Old 12-30-2019, 10:03 PM   #1
Auto leveler control panel
I was just outside and noticed a beeping sound coming from my leveling control panel ( 2017 Cedar Creek) and the LED screen was lit up and blank, when I pressed the white switch (Looks like a light switch) the beeping stopped and the screen light went out. I then pressed the on/off switch and got a ďlow voltage ď display and none of the buttons would work. Any ideas what Iím dealing with. Thanks in advance.
kimau is offline   Reply With Quote
Old 12-30-2019, 10:30 PM   #2
Are you on shore power? The white switch is actually the switch that allows you to extend and retract your slides from outside. Did you hear the hydraulic pump try to run when you pushed it? What is your battery level?
2016 Siverback 33IK, Towed 40K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
Old 12-30-2019, 11:04 PM   #3
You may need to reset the Level Up master panel located inside the left basement door (behind battery compartment). That is where it is at on our 36 CK2. The panel looks like an i-pad on the front basement wall. Press the small button on the lower part of the master panel, it should load up the Level Up system. One can then reset the panel - I don't remember the procedure. I had to do it on ours at the campground the very first night of camping.
2019 Cedar Creek 36 CK2 pushing our '19 GMC Duramax SLT
Roger & Michele
RogerY is offline   Reply With Quote
Old 12-30-2019, 11:08 PM   #4
Thanks for the reply and questions, problem solved. Iím on home power(110) and just went to check your questions and noticed that my plug was not completely seated in the cord running from the house and has drained my battery about 75% resulting in the low voltage alarm going off. Learn something new everyday. I ran the furnace and water heater/tank heater last night due to freezing temps in order to avoid winterizing for one night.
Old 12-30-2019, 11:41 PM   #5
Good to hear you have the issue resolved..
Old 12-31-2019, 02:28 PM   #6
Global Nomad
Scheinin's Avatar
Let's face it. This forum is great for solving problems. Vast majority of knowledgeable people.
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS (Center Kitchen Three Slides)
Scheinin is offline   Reply With Quote
Old 01-01-2020, 01:11 PM   #7
There is a mini breaker set were the battery cables attache. On my 36 CKTS the top one is for the pump and the bottom on is for the batteries charging circuit. They are on the left side when your facing it and are very small if any are sticking out just push them in.
BM Welder is offline   Reply With Quote
