Old 10-30-2016, 04:03 PM   #1
Awning and Patio light not working
We have a 2014 Cedar Creek fifth wheel but our outside light and awning wont work. We pulled the fuses and look fine. Any thoughts ?
Jokerbgood is offline   Reply With Quote
Old 10-30-2016, 04:26 PM   #2
Mr. Dan's Avatar
Do you have a remote control for either/both of these functions?
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 56; Booked = 52
Old 10-30-2016, 05:01 PM   #3
We do but it never worked right.
Old 10-30-2016, 05:12 PM   #4
Mr. Dan's Avatar
I'm sorry to tell you I know nothing further although someone here does (I don't have a remote in my Wildcat). I did a Search for "remote control" and found several hits. One person wrote "Porch light--if you turn it on with the remote control, it must be turned off with the remote. Porch light using switch to turn on, need to use switch to turn off." One person found a miss-wired fuse holder for his remote receiver.
Standby for help from a knowledgeable and do some searches while you wait. Sorry.
EDIT: ... another quote
Originally Posted by wally007 View Post
If you have a remote control the fuse on the remote control panel may be blown. I just replaced mine on my 2016 Wildcat Maxxx in order for even the outside switches to operate their functions
Old 10-30-2016, 05:38 PM   #5
I appreciate your help! Just discovered sliders aren't working either. So maybe it's a reset button in the front. I will give it a try during the day. Thanks again!
Old 10-31-2016, 01:42 PM   #6
About the battery under a plastic cover I have two relay disconnects, they are red and if tripped your awning outside light and some other low voltage items won't work. This is on a Blue Ridge slides will also be affected.
paulmcalexander is offline   Reply With Quote
Old 10-31-2016, 05:48 PM   #7
After lots of investigating it turns out the four batteries we have were not putting out enough power. Once we charged up the batteries everything started working. So the big question is why aren't the batteries charging while on the grid. Still have more investigating ��!
Old 04-24-2018, 03:06 PM   #8
Where is that reset button?
Dlatwo is offline   Reply With Quote
awning, light
