Old 10-22-2021, 07:42 PM   #1
wls
awning and porch/step light
Both do not work, wondering where the fuse might be. I checked the main panel, not sure if it would be up front in the storage area, any ideas? thanks
2016 FB2
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2
2016 Camping Days=38
2017 Camping Days=24
wls is offline   Reply With Quote
Old 10-23-2021, 08:05 AM   #2
SeaDog's Avatar
pull the plastic covers that hide the wires in your awning arms going to the awning light there may be an inline fuse there, this is a guess on my part good luck.
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-23-2021, 11:47 AM   #3
wls
I checked there, no inline fuse. I did go in the front compartment, saw 5 amp fuses for patio(assume that's the porch/step fuse), then the awning light fuse, all fuses good.
Old 10-25-2021, 07:43 PM   #4
Both my lights when out shortly one after the other. Replaced bulbs with LED bulbs, no problems since then.
2016 CC 34RL
2015 Silverado 3500HD DRW Diesel CrewCab Longbed
tomherb is offline   Reply With Quote
Old 10-26-2021, 04:47 PM   #5
Lights out
2016 FB2
Not sure this will help.....Our undercarriage lights and the back door light went out. There was a plug into the electrical system underneath the right side of the front door that had come unplugged.
Once we plugged it back in, no more problems.
Good Luck
Doug & Jane
DriftRoo is offline   Reply With Quote
Old 10-27-2021, 10:24 AM   #6
wls
Good Luck
I'll look for that, I did get some fuses, but have not tried them yet.
Old 10-27-2021, 10:43 AM   #7
Jim34RL's Avatar
On my Cedar Creek a 2016 34RL, there are fuse that are located at the converter behind a plastic panel in the hallway. There is also 120V circuit breakers located here also. I have had to replace a fuse in this location once do to a short.
You may know this already.
My awing light is controlled by a switch on the outside wall by the steps, with two other switches.
The porch/step light is controlled by a rocker switch, which is in the same compartment were the slide, awning switches, water heater and tank heaters are located.
I would also check the wiring at these switches too to insure the wiring is still connected.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 10-27-2021, 02:37 PM   #8
wls
{You may know this already.
I would also check the wiring at these switches too to insure the wiring is still connected}
thats my next step, I did replace the fuses, checked the 12 vt ones in the main fuse box (converter) No to the switches. Thanks
Old 10-28-2021, 09:12 AM   #9
wls
Good Luck
by the front door, do you mean the front storage door? Thanks
awning, light
