03-18-2018, 02:27 PM
Awning light
We have a 2013 36CKTS with the factory power awning. I'd like to install an LED light strip under the awning and I'm looking for 12 volt power. Can I tap into the wiring going to the awning or is there only 12 volts there when the awning switch is pushed? Thanks Steve
Steve & Jean
Furbaby - T.J. RIP
Towmotor - 2013 Chevy LT DRW Duramax/Allison
5er - 2013 Cedar Creek 36CKTS Classic Champagne Touring Edition
03-19-2018, 08:51 PM
I installed my LED and used the light switch to the right of the door that operates the light above the door on the inside.
2019 Ford F-250 6.2l gas 430 E Lock
2015 Cedar Creek 34RL
MORryde IS 7000 LB
Kodiak Disc Brakes
03-21-2018, 09:12 PM
Thanks. That might work for me as well.
Steve & Jean
Furbaby - T.J. RIP
03-21-2018, 09:16 PM
Always Learning
12v is only there while the switch is pressed.
You can often snake a wire inside the camper where the awning’s power is through the wall. And then tap off a 12v line that you find.
03-22-2018, 08:16 AM
Ok thanks.
Steve & Jean
Furbaby - T.J. RIP
03-22-2018, 08:34 AM
We bought a Solar rope light from Home Depot for about $20. Not to bright, does a great job of lighting under the awning. last long enough till we go to bed. NO WIRES INTO THE TRAILER.
'14 Cummins Dually Aisin 4.10
'07 FR Cardinal LE 30RK
'03 Cummins Dually 45RF
'01 Exiss 300MT Weekender
A wife and two dogs, isn't that enough?
03-22-2018, 08:47 AM
I ran the lead from the led light strip into the trailer where the awning power wire was routed and then ran and connected it to the step light wire along the frame so I can turn it on from the inside panel. Put a dimmer on it as well. Works great.
2017 Ford F250 Lariat Diesel 4x4
2012 Sabre 31RETS
03-22-2018, 09:21 AM
Thanks for the ideas. I hadn't even thought about some kind of solar light.
Steve & Jean
Furbaby - T.J. RIP
03-22-2018, 09:51 AM
Mine is attached to awning wire
I purchased an RGB strip and an RF controller. Ran the wires attached to the strip down the awning track and into the rig using the same hole as the awning wire than attached the strip to the awning hot side wire in my bedroom under the dresser. Works great. Biggest problem was getting the strip to mount permanently, but we solved that by using 3M Molding tape. My strip is mounted under the awning where the awning attaches to the rig. Sort of a little rain gutter under there so always protected. Love the lighting combinations, lots of positive comments.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
03-22-2018, 03:16 PM
I think I can see what you're saying but pictures please
2018 Cedar Creek Silverback 29IK
18 Silverado 3500 HD Dually 6.6 Duramax 4X4
Ultimate Aluminum 5th Wheel Hitch, TST tire monitors w/repeater
Semi-Retired February 3, 2014
Bob & Cindy
03-22-2018, 03:28 PM
Here's mine:
RF Controller was installed in the front storage cubby:
To get the wiring in, I ran it down the awning arm next to the awning's power cable, pulled back the sealant where it enter's the cabin and then poked the line through before resealing it. For power, I tapped off the power going to the front stab jacks and installed a 12v lighted switch:
The lights and the stabs would never be run at the same time, so I had no concerns about overloading that circuit.
03-22-2018, 07:34 PM
The same
Mine looks just like Kaadk's
