Originally Posted by 97flhtcui
Only connect the hose to the black flush when you are going to flush the black tank then disconnect it when you are done.
I don't disconnect and I don't have any drips.
We've had many reports here of the vacuum breaker/check valve leaking and of the hose connections (2) to them leaking and of these valves being installed backwards. This vacuum breaker/check valve needs to be inspected, IMO.
