If you are sure the battery disconnect switch is on then check the two high current fuses in the distribution panel. If you plugged in to shore power with very low batteries or shorted the batteries when working on them, these fuses would blow and prevent the convertor from charging the batteries.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
