Originally Posted by freebirds2831
If this works for you, great, but doesn't that also allow water from the black tank to move into the grey water tanks? I would prefer to keep them separated.
If you’re worried about contaminating your grey tank, you’re over thinking it. Grey water can get pretty foul. Where do you think the bacteria goes when you wash your cute little body? The two tanks are connected with a tee anyway. It’s not like they are isolated. This makes less sense than putting your tp in a bag.
If your grey tank is nearly full, you can put 10 or 15 gallons into your empty black tank a lot faster than using the tank flush, and you don’t run the risk of overflowing the black tank. This flushes the tank way better than the black tank flush alone. If you have a clear elbow and watch it, you can close the grey tank valve before anything flows back to the grey tank.
I can run the black tank flush for 10 minutes after it runs clear, then fill the tank with fresh water and will see paper and solids leaving the tank when I open the valve.
Those 360 siphon vents look like a good idea. Water softener and laundry detergent has been working well for us.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
