Old 06-20-2020, 09:09 PM   #1
Cc 33ik ac
Iím knew to the RV world ish. I should say just having multi units. I noticed there is condensation sitting under where the AC sits in the rear on camper. As week as inside the vents itís feeding. Is this a drain plug issue? The unit is 2 weeks old.
Ktminn2 is offline   Reply With Quote
Old 06-20-2020, 10:32 PM   #2
Your question is not clear. Are you having condensation inside your RV? Is it on the ceiling of the RV where the ac is mounted to the roof? Not sure what ď As week as inside the vents itís feeding.Ē means?
2016 Siverback 33IK, Towed 40K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
Old 06-21-2020, 06:48 AM   #3
It was late ha. Inside my camper. On my roof there was sitting condensation. An outline of the ac unit basically
Old 06-21-2020, 12:43 PM   #4
It wouldn’t be a drain issue. It sounds like cold air is blowing onto the ceiling. The ac is mounted on the roof and the cold air exits out the bottom into a circular ducted raceway. This raceway runs all the way to the front bedroom and picks up bedroom ac air and returns on the opposite side of the RV to the rear ac. Like a race track.
It sounds like you have cold air not being contained in the raceway where the air enters the RV.
Have you had this issue before? Did you leave a door or window open? When it is real humid and you leave a door or window open I have seen water build up on the output registers. Where are you camping?
You say it’s a new unit. Have the dealer look at it.
It does not sound like a water leak. Feel,the ceiling where you see this and see if it is cold.
Old 06-21-2020, 01:22 PM   #5
Also, how is the air flow from the ducts? Feel in the bedroom with just rear ac on. Is it pretty good?
Old 06-21-2020, 01:27 PM   #6
And one more thing... welcome to the forum. Lots of knowledge here and good folks who like to share their knowledge..
