I have a 36 CKTS, but they all work about the same. I negotiated for an icemaker with our dealer when we bought our camper. The Tech put a tee in the cold water line under the kitchen island and ran it down through the floor, then out through a cable way in the "I" beam. Then to a shut off valve. From there it goes with all the other cables and hoses to the slide. Then he reduced it down to the standard 1/4" line that icemakers need. Then, he drilled a hole up through the outer wall of the slide. If you drill about 1/2" in from the outer edge you will go right through the sill plate of the wall. Of course, you'll have to plan and measure the best spot. Mine comes up under the stove, then runs forward to the back of the refrigerator. Hope this helps you.
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
