Old 10-28-2019, 03:19 PM   #1
Question Cedar Creek 34RE water inside basement door
When I open the basement door on the entrance side of the FW, I am finding a puddle of water. This has been after a rain storm. I have looked for an entry point for the water but have not found any. I have checked the screws that hold the lock in the door & tightened them, only needed 1/2 turn each. Does anybody have any other ideas.
radio flyer is offline   Reply With Quote
Old 10-28-2019, 03:29 PM   #2
Mine does the same thing in heavy rain. It is the seal between the door and the frame. The door is slightly warped and does not seal against the frame.
2019 Cedar Creek 29RE
2017 Silverado Duramax 3500
rocco52 is offline   Reply With Quote
Old 10-28-2019, 03:47 PM   #3
Thanks for that info ROCCO52. How did you fix the problem? Did you install a new gasket?
Old 10-28-2019, 03:56 PM   #4
It is on my to-do list for spring. I have not figured out the best way to do it yet. Maybe replacing the door seal with a thicker one is the answer. You can test yours using the old "Dollar Bill" test. Close one in the door in several spots until you find the loose spot.
Old 10-28-2019, 05:19 PM   #5
Daycruiser's Avatar
BTW, if your exterior doors do NOT have weep holes on the bottom edge drill them now. They will rust out from the inside and you will pay dearly for new doors.
Retired 2020.
46 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
Daycruiser is offline   Reply With Quote
Old 10-28-2019, 05:33 PM   #6
BandJCarm's Avatar
same thing two years ago.
Look up......see the "gutter", if you can call it that? Mine has a seam, because they don't make that gutter material 40' long. At that seam, it was caulked UNDER the seam, but you could stick your finger in the hold behind it. Blowing rain, I leaked like crazy. Lots of geocell caulk later, I'm good.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 10-28-2019, 07:15 PM   #7
Jim34RL's Avatar
Mine has done the same thing. I replaced the seal with a thicker seal so far so good.I went to an auto parts store but they did not stock any weather stripping. So, I went to Home Depot and purchased the seal material there. It is a automotive style seal material and compress will around the door.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 10-29-2019, 06:53 PM   #8
Jack350's Avatar
One of my doors was also leaking after heavy rain. New gasket did not change anything on mine. Tightened screws on slam latch hardware and hasn't leaked since. Tightening latches actually pulled door closer to camper and gasket.
Jack350 is online now   Reply With Quote
Old 10-29-2019, 07:16 PM   #9
TowPro's Avatar
my brand new Forester does the same thing, I think that is why they installed those "quick drain valves" in the lower cabinets.
2019 Forest River Forester MBS 2401R
TowPro is offline   Reply With Quote
Old 10-30-2019, 06:51 PM   #10
Added a hardware store gasket along the inside edge on my door. Let it slightly overlap the edge. No more problems. Also make sure your door is centered in the opening.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
cedar creek, door, water
