Old 06-22-2020, 05:24 PM   #1
Cedar Creek 40CRS Water line question
Hello, we recently purchased a 2016 40crs. The old guy we bought it from never hooked up the water line to the fridge. I found the line behind the range and hooked it up. Only problem is, I cant find a valve to turn it on. I've checked the lines near the pump, underneath the frame, under the kitchen sink, under the slideout and Google is no help. I'm hoping someone here knows where it is. Thanks,
Shane
ShaneR is offline   Reply With Quote
Old 06-23-2020, 01:38 PM   #2
LittleBill's Avatar
Shane
I am not familiar with your unit, but mine from what I recall is underneath the refrigerator slide on the outside of the unit. It is just a white push-pull valve on a cold water line just before it goes up into the slide. I don't use my ice maker so my valve stays closed so no water goes to refrig at all. Thus I don't have to winterize/de-winterize that section of the water system as it stays winterized. I didn't know where mine was till I asked if there was a shutoff for the refrig. Hope this helps in locating it.
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2021 Chevy 3500HD Crew Cab 4X4 DRW Duramax (replaced 2015 Chevy 2500HD Crew Cab 4X4 Duramax)
Curt A25 5th Wheel Hitch (replaced Demco 18K Auto-slide)
LittleBill is offline   Reply With Quote
Old 06-23-2020, 01:41 PM   #3
I can’t even see where it goes up into the slide. I’m guessing that it’ll be under the enclosed belly pan which IMO is stupid cause if it starts leaking there’s no quick way to turn it off.
Old 06-23-2020, 01:59 PM   #4
LittleBill's Avatar
I can稚 even see where it goes up into the slide. I知 guessing that it値l be under the enclosed belly pan which IMO is stupid cause if it starts leaking there痴 no quick way to turn it off.
That's not good. I would have thought that it would need to be assessable as I would think the water line would be riding in/out with the slide. Only other thought is - Did the previous owner cap it off somewhere as they had no intention to using it and didn't want it to freeze.
Other than that I'm probably not going to be of any help, sorry. Maybe someone with your actual unit will response to your issue.
Take care and be safe.
Old 06-23-2020, 02:01 PM   #5
PO told me he never hooked it up and didn’t know anything about it other than that the filter was in a drawer.
Old 06-23-2020, 03:15 PM   #6
Daycruiser's Avatar
Call Orvan at Amish Family RV and ask him, he will probably know exactly where it is on that year and model. 260-593-0951 Jolisa will probably answer the phone, tell her what you need to know and she'll track down her dad to find out. Note: Call early in the AM as they are Amish and Jolisa is usually gone by 4PM if not earlier.
Retired 2020.
46 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
Daycruiser is offline   Reply With Quote
Old 06-24-2020, 01:19 PM   #7
On my 40crs the valve is in the rear end under slide just a simple white push pull button.
walljammer is offline   Reply With Quote
Old 06-24-2020, 02:49 PM   #8
Thanks I値l check again later when I知 back there.
Old 06-24-2020, 03:26 PM   #9
Global Nomad
Scheinin's Avatar
On my 36CKS Cedar Creek the turn on/shut off valve is underneath toward the spare tire. It is on the driver side, just above the frame. A white pull/push valve. The valve is VERY hard to turn on. In doing mine, I thought I was going to break it.
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS (Center Kitchen Three Slides)
Scheinin is offline   Reply With Quote
Old 06-24-2020, 04:06 PM   #10
My refer water valve
On my 2018 CCK ( rear BR,) 40CCK, the valve was forward on the bottom of the kitchen slide which is on the road side.
It is a white push/pull valve and hard to operate when new. My cold water line under the kitchen sink has a "T" connection and the new line goes under the floor and over to the valve and from there back to the Refer in the slide.
The drain for the line is near there too. It has a blue cap on it as I recall.
They built it that way just to make us upset.
Good luck...
Escapenrv
NC and Naples,FL
Escapenrv is offline   Reply With Quote
Old 06-24-2020, 09:48 PM   #11
Found it. I must have been blind not to see it before.
Old 06-25-2020, 12:53 PM   #12
LittleBill's Avatar
Can you tell us where you found it? Others may be looking for it too. Thanks.
Old 06-25-2020, 12:55 PM   #13
Under the slide mounted to the frame by the low point drain.
Old 06-25-2020, 01:07 PM   #14
LittleBill's Avatar
That's where mine is, but I don't think I explained it very well when I first responded to your issue. If mine wasn't at Orvan's in Indiana, I would have tried to initially post a picture of where it was to give you an idea where to look. Oh well all good now. Enjoy!
cedar creek, water
