This issue gets reported/questioned here 4-5 times per month. I call it an issue and not a problem since some here contend it's a feature. It means your thermostat has your Fan speed set to LO or HI (as you might set it for running the air conditioner) and not AU (auto).
Press your thermostat Mode button until you skip past Cool and Heat to FAN.
Press + or - key until you skip past HI and LO and stop at AU.
Press Mode back to Heat.
Let us know if this works. If it doesn't, your thermostat is probably different.
