Old 08-09-2020, 03:50 PM   #1
Changing a Toilet on a 2013 Cedar Creek fifth wheel
I have a leak coming from the pedal on the toliet. How hard is it to replace the toilet, instead of taking it to a shop?
rrekosh is offline   Reply With Quote
Old 08-09-2020, 04:08 PM   #2
Just Tryin' to Help
cboss's Avatar
What make and model is your toilet?
If it's Dometic you may just need to replace the valve. Or check the connections.
Craig & Cath
2017 Ford F250 Lariat, 6.2 gas (2022 F250 Lariat 7.3 gas with 10 speed Xmsn on order)
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2015(retirement): 1044
cboss is online now   Reply With Quote
Old 08-09-2020, 06:29 PM   #3
I have a 310 model dometic
Old 08-09-2020, 06:35 PM   #4
2 Nuts 1 seal
Turn water off and take the psi off of the water line. Now get a bucket of water and dump it down the toilet. No leak it is not the seal. Check the water line connection and or the water valve. This is a Simple Task! You can do it
mfMcFroggierPod is offline   Reply With Quote
Old 08-09-2020, 06:53 PM   #5
Thanks it is coming out of the handle on the side, once the flush is complete. I will have to change out the toliet. If I get the same model it should be the same hook up. Thanks for everyone’s help. Just don’t want to have to take it to a shop to do.
Old 08-10-2020, 12:13 PM   #6
Dahagen
If the problem is with the toilet, an attempt to fix the toilet may not work. I just replaced mine. Held down with two bolts. Easy replacement.,
dahagen is offline   Reply With Quote
Old 08-10-2020, 12:50 PM   #7
TandSH's Avatar
Had the same problem with toilet in our CC 34RL2 last year. Very easy and quick to fix. Here is link to what you need from Amazon (local dealers wanted 3X this price!):
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
More detail - valve would leak intermittently but often. I suspect it cracked due to being frozen as I had blown out system with air to winterize but the anti-siphon feature trapped water in the valve.
2017.5 Cedar Creek 34RL2
2018 F-350 Lariat CC SRW PSD 4x4
USMC Fighter Pilot (Ret)
TandSH is offline   Reply With Quote
Old 08-10-2020, 05:17 PM   #8
Thanks all I have confidence now to replace it.
Old 08-13-2020, 07:01 AM   #9
Daycruiser's Avatar
You can replace the whole toilet in 15 minutes with a newer model.
Retired 2020.
46 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
Daycruiser is offline   Reply With Quote
2013, cedar creek, fifth wheel, wheel
