Old 01-17-2020, 10:22 AM   #1
Converter
I have a 2016 Cedar Creek 33IK. It came with a bank of three batteries. Does anyone know what type/size/capability of converter they came with? Something I should just check into myself? Suspect it's behind the breaker panel? The inverter is easily accessible.
Jim 10Yes is offline   Reply With Quote
Old 01-17-2020, 10:30 AM   #2
do you have the build sheet for your trailer? it will lsit the make / model / serial number that was installed? if you don't have contact forest river using their contact form and supply your vin and they can probably supplied the build sheet.
the converter may be many places. we have a different trailer but ours is hidden behind a bulkhead in the storage bay. look in your storage bay and see if there are any small access panels on the walls. if there are take the access panel off and see if the converter is back behind the wall. of course different models could put them different places.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is online now   Reply With Quote
Old 01-17-2020, 08:53 PM   #3
keith52's Avatar
On the rear wall of the pass thru storage compartment there should be a sliding panel. Slide it open and look for the converter.
2014 Chevy CC Duramax 4X4 Long Bed
2017 Cedar Creek 36CKTS
MORryde independent suspension with disc brakes
keith52 is offline   Reply With Quote
Old 01-17-2020, 09:13 PM   #4
X2, that is where mine is on my 2016 33IK, also where the vac is located when you need to replace the bag.
2016 Siverback 33IK, Towed 40K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
converter
