Cottage 40CRS - Dump Valves
I am buying a used 2018 Cedar Creek Cottage 40CRS, no manuals.
It appeared to have 3 dump valves. One I believe for the washer holding tank toward the front where the bedroom is, then the grey and black water valves a bit further back. Everything is enclosed underneath so I couldn't see how it was plumbed.
When parked, am I correct to assume I just leave the washer dump valve open, and it will flow through to sewer?
I am just wanting to make sure there is not some sequence in which valves need to be opened. I do often save some grey water to flush out the sewer hose after dumping the black tank (which is never left open).
Mainly making sure there is not some "gotcha" I am not seeing.
Thanks!
