12-13-2020, 09:00 PM
Cross Member Frame Bracing
I have read several times of Orvan installing bracing cross bracing between the main I-beams. I was wondering how many braces were installed and if a person can tell the difference in any way.
I had assumed that Orvan had welded them in place but then I was parusing a Mor/ryde catalogue today and saw a kit for the installing the bracing. It would be a bolt on kit instead of welding.
It does not look as it would be a difficult job to do.
Any input would be appreciated.
2020 F250, 7.3 gas, 34 ft. Fifth Wheel, SOB
12-13-2020, 09:22 PM
Several of us have installed the X Factor or had it installed. It's a pretty straight forward install that takes less than an hour if you just install the center bracing. It does keep the frame from flexing inward and outward during tight turns. I made my own center brace for my old Montana with the LRE suspension, but just went with the store bought version for my Silverback. Some have installed the end two cross braces for the outer spring eye mounts, but I believe the center one is by far the most popular.
12-13-2020, 09:32 PM
Thanks for the quick reply. I'm a little confused by some of the terminology.
On your Silverback, how many cross braces did you install?
12-13-2020, 09:40 PM
I installed one ... the center one. The XFactor cross bracing is 2 U channels with flanges welded on each end. There are slotted holes to bolt them together to adjust for varying widths of frames. The two end XFactor cross braces (if you go with a total of three) are designed slightly different to accommodate the existing spring hangars. You also remove the outer spring eye bolts and replace them with what comes in the kit. I believe unless you have a 40+ foot RV that weighs a bunch ... the center XFactor will do the job.
12-13-2020, 09:47 PM
OK, I believe what was throwing me as term "X-factor". That bust be a different manufacdturer than Mor/ryde.
I'll take a look at them.
thanks
12-13-2020, 09:49 PM
Morryde makes the XFactor. It's just the marketing name.
12-13-2020, 09:56 PM
Looks like the design has slightly changed since 2011 when I installed the outer ones on a friends fiver. All 3 mounting points seem to be the same design now.
https://www.rvupgradestore.com/v/vsp...structions.pdf
12-13-2020, 09:58 PM
OK, I'll take a closer look.
Thanks for the input.
12-13-2020, 11:45 PM
I had our Silverback IK33 in the Amish Family shop in September of this year having some blowout damage repaired. Orvan suggested installing the braces, I believe the cost was somewhere around $300 - $350. I had the kit installed in his shop. They welded 3 pieces of, I think, 2”X2” square tubing. They are welded from the spring hanger on one side to the corresponding hanger on the opposite side.
To tell the truth, I can’t really say I have noticed a difference. I do believe it does help the frame, especially when trying to back into a 90 deg. Spot. I am glad I had it done. Anything that will help the frames on these rigs is a good thing.
2016 CC Silverback 33IK
2020 F350 Lariat SRW FX4
12-14-2020, 04:53 PM
Here is the "X Factor" from Mor Ryde. I installed one on the center spring mount where the equalizer goes. I installed it when I also installed the
CRE 3000 and the wet bolt kit. From the OP's post I'm not 100% sure this is what they were referring too, but this is a great addition and I may add them to the end spring mounts as well.
https://www.amazon.com/MORryde-UO21-...s%2C208&sr=8-1
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
12-14-2020, 07:03 PM
X2
Orvan did mine back in November of 2019. He installed the tubing at the spring hanger points (3).
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2021 Chevy 3500HD Crew Cab 4X4 DRW Duramax (replaced 2015 Chevy 2500HD Crew Cab 4X4 Duramax)
Curt A25 5th Wheel Hitch (replaced Demco 18K Auto-slide)
12-15-2020, 01:11 PM
Cross bracing
Are there any kits to install cross bracing on torsion axles or would that even be advisable?
04-23-2021, 06:12 PM
I realize this is a old post, but on my 2016 FB2, which has E-Z Flex suspension, would the U021-003 X factor be the one to fit this model? hopefully the link will work. Thanks
https://images-na.ssl-images-amazon....AC_SL1500_.jpg
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2, Hydra Star disc brakes,
400 watt Rich solar on top,200 watts of suitcase
04-25-2021, 03:35 PM
Green Horn
i also had ours done at Amish Family RV, I can tell a differance when towing, 29IK
04-26-2021, 05:31 AM
I just finished installing the C Factor on the front and rear besides the center that was already installed. Torn welds on hangers are all to common and are almost impossible to deal with on the road. Hopefully these will help.
2003 Duramax
2017 Crusader 315
04-26-2021, 07:34 AM
Typo above, "X" factor above.
2003 Duramax
2017 Crusader 315
