Originally Posted by steelpony5555
And get rid of those ST tires....change them for either LT tires if you are under 14k lbs or the Goodyear 614 tires if over that.....if you keep the ST's it will happen again down the road.....
X2 on the ST tires.
On my 18+k Toy Hauler - I replaced my 16" tires with the S637 tires from Sailun. The new tires were 61# each compared to the 32# each of the barely worn ST tires.
Simpletire.com is where I got mine. NTB can also get them for you.
Your second tire may have become damaged / overheated by the first tire... This is a recurring theme..
Good luck!
