11-06-2016, 07:44 AM
Door done fell off
So my daughter went out the camper to look for something the other day and texts me that the bedroom door fell off. I question her a bit to make sure I under stood her correctly and she confirmed that the door is no longer attached to the door frame. I go out to check on it and sure enough, the door pulled away from the frame. The hinges are still attached, but the wooden board that was brad nailed to the frame came free.
Anybody know of a sure way to fix it? I was thinking of using an adhesive and re-nailing.
2016 Cedar Creek 36CKTS
2013 F-450
11-06-2016, 07:58 AM
'nuther case of quality workmanship....
11-06-2016, 08:04 AM
Can you post a picture of the damaged area? We can help you fix it correctly.
2015 F-250 FX4
11-06-2016, 08:07 AM
That may be jumping to conclusions.
It is possible the door was not closed for travel at some point and the swinging/weight of the door separated the door and the frame. It would not be the first time I've seen that happen.
The weight and inertia of items bouncing down the highway can do some serious damage if not properly secured. It may have even jarred it loose and caused it to fail while sitting still.
Just another's opinion.
11-06-2016, 08:08 AM
That would be a good way to fix it. I went out myself yesterday, I said what is wrong with this fireplace. Started to check and all 6 screws pulled out of the frame. They use composite wood not solid wood. I told my wife and said hell I hope my over head cabinets don't fall off the wall..
Coachmen M/H
Concord
2018 / 300 DSC
11-06-2016, 08:17 AM
Fair statement. My comment is however, if the frame / jamb was screwed down (instead of nailed which is acceptable residential construction practice), it would probably not of fallen.
RV's really need to be screwed together, not nailed. Nails are fine in a static situation, not fine in a moving situation. I've had to 'fix' a a few items in my unit where 'nailed' items had to be refastened with screws, I just don't post it. I accept it as 'preventive and pro-active' maintenance.
Why I commented on quality workmanship...
I'd like to see mainstream RV builders screw together assemblies or epoxy then instead of using nails or staples.... Some manufacturers do, most don't.
11-06-2016, 08:18 AM
I can when I get home today.
I can't say that wasn't a possibility. It usually was closed but may have not been secured this last trip. It's not on my list of things to check prior to departing.
2013 F-450
11-06-2016, 08:22 AM
Composite wood....AKA: particle board with a veneer finish.......
Reminds me of the 'Sauder' knock down, you assemble furniture you buy at discount box stores.....
Looks good, particle board of unknown origin
11-06-2016, 08:33 AM
You are correct they couldn't use anything cheaper, the screws had to fall out just from traveling down our great highway system, hell even my island pulled out and moved 6" over at one end because it is screwed down in that laminated floor system.
Coachmen M/H
Concord
2018 / 300 DSC
11-06-2016, 09:06 AM
Ok, keep us posted.
2015 F-250 FX4
11-06-2016, 09:42 AM
The doors on most RVs are wood? Framed and Cardboard filled ! I made a panel door for our V lite because F/R didn'the offer panel Cherry doors,I used the same hinges that were on the Paper door! I had to use a better door knob assy though! Youroo! !
11-06-2016, 12:59 PM
Door fix
We also have a 36ckts. We found that in travel, the bedroom door would "unlatch" causing it to swing back and forth. We went to Lowes and got a strong magnetic catch. That enabled the door to stay in the opened position and not swing back and forth during travels.
Here is the link.
https://www.lowes.com/pd/Gatehouse-1...tector/3353172
2014 Chevy CC Duramax 4X4 Long Bed
2017 Cedar Creek 36CKTS
MORryde independent suspension with disc brakes
11-06-2016, 01:12 PM
Jack of All Trades
If the ftame is wood, reattach the board and use longer screws through the hinges, board, and into the frame. (Same thing you doe in S&B home if a door hinges come loose).
Rick
Rick & Debbie; Brandy Schnoodle & Bucky (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
11-06-2016, 02:57 PM
Sorry it took so long been running non stop today.
2013 F-450
11-06-2016, 03:03 PM
World Wide Wanderer
Screw and glue...
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
11-06-2016, 03:25 PM
Originally Posted by wahoonc
Screw and glue...
Aaron
I agree just use some glue and then some long screws that will hold iy
Coachmen M/H
Concord
2018 / 300 DSC
11-06-2016, 04:36 PM
Too old to be too smart
If recommending "glue", it's a good idea to specify a very-specific type with which you are confident will be appropriate.
"Glue" could mean ANYTHING that's adhesive.
Super-glue (cyanoacrylate)
Gorilla (polyurethane)
Titebond (aliphatic)
Scotch Spray (trade secret)
Hundreds more (some will work in this application, some won't)
See what I mean?
Thanks for any additional info you can lend to this.
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
11-06-2016, 05:23 PM
I have used the professional grade subfloor construction adhesive many times, good stuff, I get it at Lowes. Looks like a sidewall, don't use too long of a screw, your next post will have a pic of the outside of the RV. with a screw sticking out!
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
11-06-2016, 05:24 PM
World Wide Wanderer
See what I mean?
Pop
Well as a general rule I use wood glue for wood...
I suppose you could use something else.
Aaron
Aaron & Rhonda
11-06-2016, 05:32 PM
Liquid Nails or some construction adhesive.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
