I'm confused by post #7. Is the tank indicating full or empty? If it is full, I recommend that you unhook or turn off city water. If you don't want to fill a grey water tank, then open an outside shower faucet - in fact, it would probably be good to unscrew the shower head from the hose because you may get some debris coming out of the pump. Pump the fresh water tank down to 3 out of 4 lights on (2/3 level). Cycle the pump on and off at least 3 or 4 times as you pump the water out. Also with the pump running, open and close the faucet valves 4 or 5 times as well, letting the water pump turn itself off.
Hopefully that will get any debris out of the check valve and it will reseal. Then you can open the drain valve and drain the fresh water tank. Once it stops draining, leave the drain valve open, then turn city water back on and watch the drain to see if the check valve is leaking.
Might want to turn off the water heater while you do all this.
