04-28-2016, 02:13 PM
Drain valves
I have the 38FB2, with 2 black tak valves. The one valve that is located under the frame for the small bathroom is stuck solid, I try with all my might to pull it to dump. What are you guys recomendation to get it to move. Maybe take some spray stuff, like PB blaster etc to it? Thanks
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2, Hydra Star disc brakes,
400 watt Rich solar on top,200 watts of suitcase
04-28-2016, 02:35 PM
Did it ever work?
Sometime a squirt of silicone spray at the valve blade where the rod attaches will work its way into the valve and make the blade slide easier.
04-28-2016, 02:37 PM
I spray my valves with a silicon lubricate all of time. Keeps them working easily. If yours is that stuck I would try spraying with a penetrating type spray and let it sit there for some time and then spay it again. You can pull the plastic handle off the end of the shaft if it is really stuck. If that does not work you may have to start taking the valve apart to loosen it up.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
04-28-2016, 07:06 PM
Originally Posted by 5picker
Did it ever work?
Not sure brand new. The sheaved cable runs up thru the plastic underbelly shield I can't see the valve itself.
I'll see ifI can take a pic
04-28-2016, 07:27 PM
Here's a couple pics, hopefully you can see it
upside down, but better then none, LOL
04-29-2016, 07:05 PM
got it to work, sprayed it, then took some pliers and twisted a little.
