Old 10-29-2018, 04:35 PM   #1
Electric Fireplace smell
My 2019 Cedar Creeks electric fireplace smells like something is burning when the heat is on. I took it apart and dont see anything obvious. Has anyone else had issues with theirs ? It's bad enough that after you turn it off the trailer smells like smoke.
DBrice is offline   Reply With Quote
Old 10-29-2018, 04:54 PM   #2
How much have you used it?
Many electric heaters (and R/V furnaces for that matter) stink and smoke for a bit when first using them. Run it a half hour and see how it fares.
Days Camped: '18=51 '19=58 '20=110 '21=94
Old 10-29-2018, 04:57 PM   #3
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I'd say if the smell, if it smells like dust and oils burning off, doesn't go away after the 1st initial use then you may have a problem and have to take it to the dealership for inspection, an electrical fire is no laughing matter.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
Old 10-29-2018, 05:04 PM   #4
Flybob's Avatar
X2 on dust and oil from manufacturing burning off. Be aware that your propane furnace will do the same thing the first time you use it. The dealer should have recommended you run each for about 30 minutes on a warm day with windows and door open before you need them to keep warm.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-29-2018, 05:17 PM   #5
BuzzWolfAR's Avatar
Opened my windows, ran my fans and ran the fireplace about two hours.
Love it now, but took time to clear the smell.
Similar experience with the furnace.
Buzz & Jo Wolf
5er: 2018 Cedar Creek 29ik
TV: 2014 F350 Diesel
BuzzWolfAR is offline   Reply With Quote
Old 10-29-2018, 05:20 PM   #6
Thanks everyone, we have ran it in the past for short periods. This time it was on for a couple hours when it started to stink.
Old 10-29-2018, 05:29 PM   #7
If it didn't do it before but does now, either something crawled in there and died (you wouldn't be the first) or something has dropped into the unit.
You may have to completely remove the unit and disassemble to find out what's going on.
I wouldn't use it until you do so or take it back to the dealer. A 2019 should be under warranty unless there's a dead animal in it.
electric, fireplace
