Old 04-09-2018, 06:33 PM   #1
Extension crank
Dumb question of the day.
On our new Cedar Creek RE34, we found one of those 4' long extended crank handles under the bed.
What is it for? We have hydraulic leveling and slides.
No,one at the PDI mentioned it.
tomkatb is offline   Reply With Quote
Old 04-09-2018, 06:39 PM   #2
Homebrew's Avatar
Spare Tire ?
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is online now   Reply With Quote
Old 04-09-2018, 07:53 PM   #3
Send a message via AIM to splong16
Most likely it is your spare tire crank
2017 Cedar Creek 36 CKTS Hathaway
2015 GMC Sierra 3500 4x4 SRW CC
splong16 is offline   Reply With Quote
Old 04-11-2018, 08:26 AM   #4
Itís for your spare tire and itís something you need to check occasionally. My spare actually came loose. Nowadays I make sure the spare is tight
spock123 is offline   Reply With Quote
Old 04-12-2018, 05:24 PM   #5
Mine came loose too, so now I check it more often. I have also run a ratchet strap across it as a back up. Works great.
tomherb is offline   Reply With Quote
Old 04-12-2018, 05:37 PM   #6
Thanks all.
Will check next time out.
Old 04-12-2018, 09:54 PM   #7
dieselguy's Avatar
tomkatb ... just to put forth some info when you mentioned hydraulic slides and levelers. For emergency use if your hydraulics won't work electrically ... you'll need a 1/4" allen bit to go in a cordless drill to power your slides or landing gear. It doesn't come with your unit. You'll also need an 5/32" allen wrench to use on the slide or level up valves to turn the set screw clockwise to allow manual operation. Page 47
https://www.lci1.com/assets/content/...e_27July17.pdf
dieselguy is offline   Reply With Quote
