09-13-2017, 09:05 AM
Fifth wheel hitch removal and re install.
Anyone have a solution to the task of taking the fifth wheel hitch in and out of the back of a pickup ? Have a Curt Q-20 that weighs around 140 lbs.
09-13-2017, 09:11 AM
Get an Andersen, 40 lbs
If not camping, I am Sailing
09-13-2017, 09:17 AM
I just manhandle it. Makes it easier to do it in two parts. But my wife helped me with it last time I took it out so I didn't take it apart. She's pretty strong. I'll rent her to ya.
Sorry, she loves Snoopy.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
09-13-2017, 09:24 AM
One way is to leave it hooked to the kingpin, and disconnect from truck, then drive away. Reconnecting is more difficult but doable.
FROG AR-0019-242
09-13-2017, 09:25 AM
Leave it attached to your pin, pull the four rail pins and lift the front of the fifth wheel, drive out. do the reverse when you put it back in.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
09-13-2017, 10:31 AM
Etrailer has a Demco Fifth Wheel Lifting Bracket that works well if you have a winch, engine crane, tractor, etc., that you could use to lift it out.
I will second the Andersen hitch as being the easiest to remove and reinstall.
Gotta go campin!
09-13-2017, 11:13 AM
Leave it in. Then you have an excuse to not haul everyone's crap for them
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
09-13-2017, 11:17 AM
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
09-13-2017, 12:12 PM
Location: Alberta - East of the Rockies, West of the Rest
I feel your pain, literally. As already suggested a tractor or crane would work but the Andersen Ultimate hitch is the way to go.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
09-13-2017, 12:28 PM
I bought a hydraulic lift table from Harbor Freight. I release the hitch then slide it to the edge of the back. Pump up the Hydraulic table and slide the hitch onto it. Then I roll the table to where ever I store the hitch and lower it back to ground level. When time to reinstall, I pump up the table to the truck height and slide it back onto the bed and install.
My hydraulic table at max height is about 2 inches lower than I want so I use some 2 x 12 wood pieces to give it that little bit extra. Works great for me.
09-13-2017, 12:30 PM
I have a Reese 16K slider and I take the top part off and then remove the lower part. It's about 140lbs together, so it's heavy. I'd like to leave it in but I need my box for work. I saw a unit at my storage lot that left theirs hanging on the king pin. That looked like a good idea, but I worry about theft. I doubt it would cause any damage.
2017 F150 XLT 3.5l Eco Boost, SC, 8' Box, 4X4
Max Tow (10 speed, 3:73, 11,700lbs), HD Payload (2440lbs)
2015 Puma 253 FBS
2013 Hyundai Santa Fe
2000 Honda EX 400, Rad Rover 6 Plus
09-13-2017, 12:31 PM
Neighbor rolls up his engine hoist, chains it up, lifts, rolls into his garage, drops on a skid...done.
09-13-2017, 12:55 PM
I saw a picture on pintrest that showed a table this guy had made. It was on wheels and was the height of his truck bed. Slid the hitch to the edge right onto the table. When he was ready to put it back on reverse the process. you still need to lift it back on to the rails. I can't use it as I would have to the table over gravel, so I only take it out if I really need the space.
2015 Phoenix 32RE
2002 F250 V10
09-13-2017, 01:05 PM
This would work if your have an unfinished garage like I do. I use a chain hoist from Harbor Freight. Lift it up, drive out and lower onto furniture mover.
DYNAMAX 2016 FORCE HD
09-13-2017, 01:17 PM
I either leave it connected to the King pin for short term. I use a Harbor Freight engine hoist for longer term removal.
I unloaded by hand only once. Never again.
Alan and Kim
2013 Surveyor 293 RLTS
2013 F250 Lariat
09-13-2017, 01:22 PM
Frog-Toberfest Organizer
I got tired of heavy hitches and switched to Anderson.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=47 '20=47 '21=64 '22=62 '23=72 '24=0
09-13-2017, 01:39 PM
I also have a Q20 Curt in my F350 long bed. Because I have a gooseneck plate that also fits on my rails, I am constantly swapping back and forth. Most of the time I use the front loader on my JD tractor to pick it up and out of the bed but a lot of times my tractor is not here and handy.
At that point, I just pull the two large pins that hold the top section to the base and take it out in two sections. Very doable that way and it gives you a chance to put some fresh grease into the saddles that the top section fits in.
Sometimes, especially if you haven't had it apart in awhile, it is stubborn to release easily. You can just take a small pry bar or crowbar and stick it right under the large diameter rods of the top section and give them a lift up. They'll come right out. Then put some fresh grease in there.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
09-13-2017, 01:45 PM
Hitch Removable
X-2, Engine hoist, what do you mean you don't have an engine hoist? All rv er's need an engine hoist. To be fair, I've always worked on race cars so an hoist was mandatory, good luck.
Yeah I have the Q24 in my 350 and when you take apart it's easy. Just like you mentioned, can be a bear to get apart sometimes.
Dwayne and Susan
