Old 10-11-2018, 08:53 PM   #1
FIREPLACE new 2019 CC 36ck2
We cant pull out fireplace!
Sign says pull here.
We have pulled, pressed,pushed.
Do I need a Magic Decoder ring?
Thanks.
2019 CC Hathaway 36CK2
2006 Ram 3500 Dual Wheel Cummins
Fleetwood PA
acvp1 is offline   Reply With Quote
Old 10-11-2018, 09:09 PM   #2
As a matter of fact you do or at least you do on my 2018 34RL2. There is a ring at the bottom of the fireplace that connects to a pin that needs to be pulled down fully towards the floor before the fireplace will move. I actually had to replace the wire ring with a heavy duty key ring on my fireplace because I bent the wire ring trying to get my fireplace out.
I hope this helps.
Fireman1 is offline   Reply With Quote
Old 10-11-2018, 09:13 PM   #3
Thanks! I will try that. I pulled it and being strong I pulled than thin metal ring and stretched it oblong. I will get a stronger KEY RING and install that....and will pull down pin, then attempt to pull it out. Thanks very much!
Fleetwood PA
fireplace
