They are wired for a King which means that two cables come from the King to two separate dish receivers, one in the Living room and one in the bedroom which feeds the exterior through a modulator. If you use the Winegard, then you can only feed one receiver which I'm sure would be the main in the LR. You could use either Dish or Directv. I would guess you could find a way to connect the two wires. In 2018 CC intended for you to use The King. I assume you have three TVs that are operating off your air antenna?
Hugh and Fran
"Riley" the dog
2018 Cedar Creek 38EL Champagne
2017 Ford F350 SRW CC SWB 4x2
Demco Hijacker Autoslide 18k Hitch
