Old 01-28-2018, 01:04 PM   #1
Gr8Dane777's Avatar
Floor Board Splitting
Anyone ever have this happen?? Was flushing tanks this morning, looked up in under belly and saw this in multiple spots
ID:	161083   Click image for larger version
Gr8Dane777 is offline   Reply With Quote
Old 01-28-2018, 01:53 PM   #2
Hoglou's Avatar
depth
As plywood is a layered product is it just on the outside layer, or does it run the depth of the wood? If it is a complete split of all of the layers (and I would bet it is not), and still in warr then dealer it goes. If it is just a layer I doubt they would bother with it, as it may well be the grade of plywood they use and have little structural significance. You may consider glue and screw another sheet of half inch on both sides of the rails, but I like to reinforce everything.
Regardless, seeing "raw" plywood exposed that looks like non treated or external grade I would seal it with some product or another.....
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 01-28-2018, 01:57 PM   #3
Gr8Dane777's Avatar
It does run the depth of the wood, the dark you can see it whatever is on top of the wood, feels like underside of carpet??
Old 01-28-2018, 02:15 PM   #4
Kanadian Kamper
kenandterry's Avatar
Have you figured what/where is above the crack when you’re inside?
Ken and Terry
2018 Sunseeker 2430S-CD
and if we ever need it, can be pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 01-28-2018, 02:20 PM   #5
Flybob's Avatar
Looks like it is inside a basement or other enclosed area and not open to weather. Depending on what has to be removed/ disassembled to fix it, might be easier to seal crack and laminate a piece the entire size of the space between the aluminum frame pieces for strength.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-28-2018, 02:55 PM   #6
FordHauler's Avatar
In the first photo it appears that the aluminum framework is bent downward at the crack. Something very heavy being dropped at that spot?
Plywood has layers that run opposing directions, a crack like that should be impossible without great force.
Are we seeing light thru the crack?
The second photo looks similar to what you would expect on the underside of A/C grade (one side good) plywood.
Travel safe
2019 Ford F-350 Super Duty CC Dually 6.7 Diesel
2011 Cedar Creek 36CKTS Touring Edition
I Catch Fish......What is your SuperPower?
FordHauler is offline   Reply With Quote
Old 01-28-2018, 03:14 PM   #7
am I seeing "Light" or "Daylight" thru the first crack?? That is a large crack. that needs looking into.
Old 02-09-2018, 06:12 AM   #8
Travel safe
My thoughts as well.
Brickie is offline   Reply With Quote
Old 02-09-2018, 07:34 AM   #9
Gr8Dane777's Avatar
Aluminum is not bent, just flash of camera that makes it appear that way. No light seen through crack.
Old 02-09-2018, 08:06 AM   #10
Just another example where the manufacturer's try to save as much money as the can by using the cheapest materials as they can. I have a TH with soft spots in the floor you can feel just walking across them. I haven't loaded my motorcycle in it yet, sure hope it holds up when I do. As already stated, I think I would let the dealer fix it or add some plywood to reinforce it. Good luck.
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
hdmtnrider is offline   Reply With Quote
Old 02-09-2018, 08:39 AM   #11
How thick is the wood and is it plywood?
It would be odd for plywood (multiple layers of wood with cross-stacked grained layers) to have a crack go through all the layers to where you could see carpeting above.
What is directly above the crack on the inside?
Days Camped: '18=51 '19=58 '20=110 '21=94
Old 02-09-2018, 08:52 AM   #12
Gr8Dane777's Avatar
Looks like thin plywood to me. Hard to tell what is above it. It’s black and feels coarse like what you would think would be underside of carpet, but hard to tell??
Old 02-09-2018, 08:58 AM   #13
Just as confused as you
Scrapper's Avatar
The black you see in the crack is the adhesive on the next layer of wood. IMO you have nothing to worry about. If you go to a lumber yard and examine the plywood panels you will see most of them with the same condition. Plywood without imperfections on both sides is expensive and not used for flooring. The plywood in your RV is at least 1/2 inch thick, made from 5 layers of wood, glued together with heat and pressure.
Plywood is made in various thickness from 1/8" to 3" thickness. The number of plies, which is always odd, depends on the thickness and grade of the sheet. Sub-floors are at least 3/4" thick, the thickness depending on the distance between floor joists. Plywood for flooring applications is often tongue and groove. This prevents one board from moving up or down relative to its neighbor, providing a solid-feeling floor when the joints do not lie over joists. T&G plywood is usually found in the 1/2" to 1" range.
Richard & Jill
Old 02-09-2018, 09:04 AM   #14
I agree with Scrapper. That appears to be the outer ply of cdx plywood or some such, which is made with a low grade ply on the bottom side.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 02-09-2018, 09:10 AM   #15
Gr8Dane777's Avatar
It is still under factory warranty, should I leave it alone, or take to dealer?
Old 02-09-2018, 09:26 AM   #16
How deep is the crack and how thick is the plywood? What sits on top of the plywood in this location? That info would help answer your question.
Andersen hitch
Old 02-09-2018, 09:33 AM   #17
Me it would be back to the dealer. Others might try and fix it but I would take it back and have them fix it. Just MHO.
Gonefishing1 is offline   Reply With Quote
Old 02-09-2018, 10:09 AM   #18
Gr8Dane777's Avatar
Plywood is maybe 1/4”, underside of flooring sits on top
Old 02-09-2018, 10:24 AM   #19
It never hurts to ask, but I expect they will tell you this is CDX sheeting and is normal for this product. It apparently does support a lot of weight and is not an appearance issue.
Andersen hitch
Old 02-09-2018, 10:34 AM   #20
Thanks and I know we keep asking about the thickness of the wood and what's on top but these are really important questions.
One, if it is truly only 1/4" thick plywood, I would have much concern.
1/4" plywood isn't thick enough for a sub-floor and certainly not across the spans (aluminum framing) we see in the photo. The only thin wood material I've ever seen for flooring was that which is bonded to a foam core top and bottom. Not an ideal floor but comes in at about 1-1/2" to 2" thick. Typical plywood floors are 1/2"-3/4" not 1/4"
Two, when asked what is on top of the crack... we are referring to what is actually inside the rig at that spot? A bed? A dresser? The bathroom?
If your floor is 1/4" thick and you can actually touch the underside of the carpeting through the crack, you have what I'd describe as, MAJOR issues.
We are simply trying to get a good grip on what is actually going on with your floor.
floor
