06-17-2018, 07:17 AM
#21
Originally Posted by CharlieS3
If you have a winterization port, you may be able to suck water/bleach mix into your main tank. It depends on your setup.
that's how i did mine
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2, Hydra Star disc brakes,
400 watt Rich solar on top,200 watts of suitcase
06-17-2018, 09:32 AM
#22
Originally Posted by CampAndSki
I should have been more clear. Our water filter is not built in to the system. CC didn't provide/install the filter. Our filter is outside the camper and connected to the FW/City water inlet. I switch over from City to FW and the water, coming through the filter, is pumped into the FW tank.
X2 again
Hugh and Fran
"Riley" the dog
2018 Cedar Creek 38EL Champagne
2017 Ford F350 SRW CC SWB 4x2
Demco Hijacker Autoslide 18k Hitch
06-17-2018, 12:27 PM
#23
That may work for some setups, however with many if not most setups the winterization port feeds directly to the pump and water lines for adding antifreeze, bypassing the FW tank entirely. Otherwise, antifreeze would be pumped into the FW tank, which is both not necessary and also very hard to get the taste and smell out.
Some setups have a lever to select to pump from the winterization port into the FW tank for adding water to it, or pump directly to the lines for antifreeze.
2016 FR Forester 2401R
Towing 2014 Honda CR-V
06-17-2018, 01:46 PM
#24
How do you sanitize the top, inside of your fresh water tank?
Bruce
06-17-2018, 02:07 PM
#25
Bruce
You use the appropriate concentration of bleach for the size of your tank and fill it to the very top with water. Then let it soak for 12+ hours.
06-17-2018, 02:16 PM
#26
How do you fill it to the very top? Isn’t an air pocket created that will prevent the water from reaching the top of the tank? Or are all of the vents attached at the top of the tank?
Bruce
06-17-2018, 02:22 PM
#27
With a previous trailer I owned, the fresh water tank was under the bed. The tank was translucent, so I could see the water in the tank. The vent came out of the top of the tank, but the tank would never fill all of the way to the top — maybe about an inch or so below.
Bruce
06-17-2018, 02:43 PM
#28
Bruce
I don’t know if you can do this with a larger trailer, but I push the side of my Clipper a few times to slosh the water around a few times while it’s sitting with bleach...
Carmen and the pack
2015 Coachmen Clipper 17BH
2017 Dodge Durango Citadel 5.7 Hemi
06-17-2018, 03:18 PM
#29
Take it for a drive.
2011 Traverse LT, 3.6L, FWD
06-17-2018, 10:40 PM
#30
In a typical unit with a fill port the water will fill to the top of the tank then rise up through the fill neck to the port.
Your results may vary depending on your setup. But I can't see any logical reason why a manufacturer would want to leave an air gap at the top. That would be lost volume.
To avoid gaps, level the RV, and if necessary level the tank if it's not level when the RV is level.
06-18-2018, 12:04 AM
#31
On many tanks, the fill and vent lines enter on the side, not the top. This is especially true when the tank is mounted up against the bottom of the floor. In order to attach the hose fitting to the tank, there must be 1/4" to 1/2" of area around it, so the top of the hole into the tank is often 1/4" to 1/2" below the top of the tank. So you can't really fill it "full."
See this one, for example:
Now if your tank looked like this, you'd be correct. But this kind of tank is usually mounted on TOP of the floor.
You appear to have a Class C, which probably has the tank mounted above the floor (probably under the bed). Most travel trailers are not built that way, but have the tank UNDER the floor, and hence cannot be completely filled.
06-26-2018, 12:21 AM
#33
Originally Posted by rockfordroo
The OP doesn't have a gravity fill that you can put a funnel into. He only has a hose connection, below the blue valve handle. The blue valve handle directs his city water from the hose connection either to the RV or to the FW tank. There's a check valve located in the hose connection, so you can't really insert a funnel. That's why you pour it into the hose, then hook up the hose and fill the tank.
Yes, I got that; it just seems unnecessarily complicated to have to do that to do something as simple, necessary and recurring as that, using a hose in the manner described.
06-26-2018, 08:04 AM
#34
I just pour a cup of bleach into my water hose, then connect it to the fresh water tank, turn on water and it pushes it right into the fresh water tank. I open all the faucets and run water until I smell bleach. Live in system for a few hours, drain tank, fill with fresh water, run faucets again, drain tank again, fill tank with fresh water again, run faucets again.
Bleach smell should be gone if not flush it again.
06-27-2018, 03:46 PM
#35
Bruce
Bumpy dirt road
Sent from my Moto G (5) Plus using Forest River Forums mobile app
07-21-2018, 04:22 PM
#36
54 Years, 13 RV's
I've not seen this question...... is it okay to leave the proper ratio bleach solution in the tank and lines for a few weeks while waiting for the next trip?
Of course flushing it out prior to leaving.
2021 Rockwood 2511S
2020 GMC 1500 6.2L
07-21-2018, 04:25 PM
#37
I use about a cup
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
07-21-2018, 04:32 PM
#38
Always Learning
Yes.
07-21-2018, 05:25 PM
#39
54 Years, 13 RV's
Originally Posted by ependydad
Yes.
Thanks.
2021 Rockwood 2511S
2020 GMC 1500 6.2L
07-27-2018, 08:48 PM
#40
Adding bleach to fresh water tank (sanitize)
Has anyone tried a siphon mixer to add bleach to fresh water tank to sanitize?
