First, you need to ensure your battery cutoff actually cuts off everything 100% or you will have dead batteries when you return unless you have it wired for solar to charge the batteries with everything else cutoff. About the only way to do this is do it yourself. Factory installed cutoff switches do not cut off many parasitic draws.
If you have a residential fridge, your unit has an inverter that will convert 12v to 110 to run your fridge. It also has an on/off switch you should employ.
But if you have a 100% battery cutoff, have shore power at your storage site, or properly use your solar, then no worries.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
