Before we edited the button name for the tank heater, it was Aux trigger #1, which controls 12VDC power to terminal #31 on the circuit board in the basement storage area, which is (in our case) where the factory connected the heaters. It can be selected to either momentary or latch. When latch is selected it provides continuous 12V power to whatever it is connected to. Since the heaters are not accessible there is no way to actually verify power at the tank heater pad. As with all campers we have owned the tank heaters are all connected together (saves cost). Agree it would be better design to have individual switches. I was able to verify voltage (on-off) at terminal #31 with a multimeter when the button for the heaters was turned on and off. When momentary is selected instead of latch voltage is only available when button is pressed..... similar to the way your awning operates, if you lift your finger from the button motion stops.
