Old 04-10-2020, 12:16 AM   #1
Hot water heater help
I have a 2004 cedar creek. We de-winterized it. Put the plug in the water heater, hooked up the water and tested the heater. We had hot water. Now we are at the campground and no hot water.
Does anyone have suggestions of what to try? No visitors allowed, so I can't get any help with it.
dallasrules is offline   Reply With Quote
Old 04-10-2020, 06:27 AM   #2
Did you fill the WH? Turn the valves behind the WH. I hope you didn't turn the WH on electric without filling the WH. If you did you need a new heating element.
Gas on? Electric on?
Old 04-10-2020, 07:06 AM   #3
KyDan's Avatar
Since you say you tested it at home and had hot water we assume it's full of water??
When you tested at home did you use LP gas to heat it or electricity??
Now that you're camping are you trying to heat with LP or Electric??
Maybe you figured it out and went to bed???
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41, 2021-42
KyDan is online now   Reply With Quote
Old 04-10-2020, 07:11 AM   #4
Georgia Rally Coordinator
aceinspp's Avatar
Have you made sure that the water by pass valve is turned in the right direction. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49 days camped 2021-38
Old 04-10-2020, 10:27 AM   #5
water heater
Do your valves look like this?
If so
Heres how they should be for sommer use.
Set for winterizing.
C.B.
cbvp is offline   Reply With Quote
Old 04-10-2020, 03:34 PM   #6
ARLO
What type of water heater? gas or electric side?
rlocicero is offline   Reply With Quote
Old 04-10-2020, 05:55 PM   #7
BillyBass's Avatar
what did you try it on at home gas or elec when you got hot water.On mind i have two switches for elec and one for gas
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
BillyBass is offline   Reply With Quote
Old 04-11-2020, 12:11 AM   #8
Guess he figured it out!
Old 04-11-2020, 06:10 AM   #9
Mike223's Avatar
Ditto.
Mike Gray
Forest River Wildwood
2018 230BHXL
2015 Sierra SLE 5.3 V8 4x4
Mike223 is offline   Reply With Quote
Old 04-11-2020, 06:14 AM   #10
aceinspp's Avatar
Maybe she didn't want to admit he for got to turn the by pass valve. Later RJD
Days camped 2019 62
Old 04-11-2020, 06:56 AM   #11
Mr. Dan's Avatar
He’s a she.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 56; Booked = 52
Old 04-11-2020, 07:35 AM   #12
Originally Posted by Mr. Dan View Post
Heís a she.
It's very hard to tell these days
Old 04-11-2020, 07:52 AM   #13
Mr. Dan's Avatar
First name = Ruth
Gender === female gave me clues.
Old 04-11-2020, 07:54 AM   #14
aceinspp's Avatar
Heís a she.
Without going to profile one did not no and I did not check it. Later RJD
Days camped 2019 62
Old 04-11-2020, 08:19 AM   #15
Mr. Dan's Avatar
Ha! I like your edit where she blamed a he for forgetting!
Old 04-11-2020, 06:41 PM   #16
Hi everyone. Thanks for all the responses. Sorry I didn't reply sooner.
So, here's what happened. My old trailer had a switch inside for the electric ware heater. We never used it on propane. We just turned the switch on.
So, when I tested it at home, we turned on the switch that said water heater (after filling it ) and then we had hot water. It was a bit chilly at the time and we had the propane on for the heat.
When we got to the campground and turned the switch on, no hot water. We did not have the propane on. So the switch is for the propane. After watching a video, I found the switch on the tank for electric. It is tucked back in there good. It is really hard to push the switch, but both the propane and electric do work.
Also, there is only on switch in the water lines to cut the water on and off. No bypass. I guess it has a backflow inhibitor or whatever it is called.
I did read the how to section on here as well and that helped. I think I will take the time to work my way through some of the other how it's as well. I guess I should have done that before I asked, but you guys are always such a fountain of knowledge
Thanks again.
2006 Dodge Ram 3500 diesel
2004 Forest River Cedar Creek 30CKTS 5th wheel
2002 Fleetwood Terry 29' 5th wheel
1998 Carri-lite 34' 5th wheel
Old 04-11-2020, 06:47 PM   #17
Mr. Dan's Avatar
Thanks for returning and posting your findings. This may help others with the same issues.
Old 04-11-2020, 06:55 PM   #18
My two trailers both have had just one valve and a check valve. Very common set up. Suburban has the outside electric switch. Atwood does not. Suburban also uses an anode rod. Atwood does not.
heater, hot water, water, water heater
