I don't know how the hydraulic systems are set up on the RV's. There should be a way to bleed the pressure off the hoses without having to crack the lines loose. May disconnect the wires from the motor, then working the valves either by hand or by the directional switch. After relieving the pressure then you could run your fingers along the hoses, feeling for irregularities. The hoses should not have bumps or wrinkles.
Check the hoses carefully in case they have steel wire braiding in them. When the wires break they are as sharp as sewing needles. Hope I gave you some ideas.
Richard & Jill
