Old 06-04-2020, 03:07 PM   #1
Hydraulic hose leaks
Have a 2014 36CKTS and it developed a hydraulic leak this spring. Found the hoses must have been damaged during assembly and covered up with matching tape. Pic attached. Anyone have similar issues
ID:	230703Click image for larger version
ID:	230704Click image for larger version
HWCbob is offline   Reply With Quote
Old 06-04-2020, 05:25 PM   #2
Just as confused as you
Scrapper's Avatar
Hydraulics work under high pressures, 1000 psi and above depending on the pump used. There is no amount of tape that will stop a leak. You will have to take the hose to a farm supply store such as Central Tractor, Fleet Farm, Farm & Fleet, or Tractor Supply and find one that matches. Hydraulic repair shops will make what you need on the spot.
Richard & Jill
hydraulic, leak
