Old 09-22-2020, 09:12 AM   #1
Included 50 amp power cord
Can someone tell me how long the power cable is that Cedar Creek provides. Also, is the power port on the trailer a 4 prong female?
2021 Cedar Creek Cottage 40CRS
Victron MultiPlus-II 12/3000/120-50 Solar installation
SacRV is online now   Reply With Quote
Old 09-22-2020, 09:25 AM   #2
I don't have a CC... but... most R/Vs come with either a 25' or 30' shore power cord.
50 amp service is 4 prong.
The R/V receptacle is a twistlock male... the cord end that plugs into the R/V receptacle is a twistlock female.
Days Camped: '18=51 '19=58 '20=110 '21=98
Old 09-22-2020, 09:42 AM   #3
Jim34RL's Avatar
My Creek's power cord is 25' long. I have found that in most cases this is lone enough for the camp grounds that I use. I would also recommend a portable surge protector of some sort. This provides about a foot to the length of the power cord in my case.
This seems to be the standard length for 90% of the 50 AMP power cords for all trailers. When we set up at a camp ground I check to insure that the cord will reach before un-hitching. This way I can reposition the trailer if required for the power cord to reach. I do not worry about fresh water or sewer lines length, as I have enough to reach 50' if required.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 09-22-2020, 11:58 PM   #4
LittleBill's Avatar
2 1/2 years ago I bought and a 50 amp RV extension cord from Walmart as my normal cord wouldn't reach my 50 amp box at home. This is what I bought though it is about $15 more than I paid for mine at the time - https://www.walmart.com/ip/Camco-551...-Cord/29764590
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2021 Chevy 3500HD Crew Cab 4X4 DRW Duramax (replaced 2015 Chevy 2500HD Crew Cab 4X4 Duramax)
Curt A25 5th Wheel Hitch (replaced Demco 18K Auto-slide)
LittleBill is offline   Reply With Quote
Old 09-23-2020, 07:01 AM   #5
PhD, Common Sense
When people add an extension cord to their RV power cord, do they ask the questions, “What is my new length of cord?”, “What gauge is required for that length?” and, “What gauge are both the extension and the power cords?”
When the manufacturer makes a single cord and lists a current rating on it, I have faith that they have ensured the correct gauge for the length of the cord. When people add extension cords, the manufacturer can’t possibly know what the new length will be, and can’t have guaranteed the correct gauge for that new length. That becomes the responsibility of the person creating the new length.
Manufacturers probably use a heavy enough gauge to handle longer lengths, but are extension cord users sure that both cords are of sufficient gauge?
eye95 is offline   Reply With Quote
Old 09-23-2020, 07:44 AM   #6
KyDan's Avatar
I have no qualms about adding an extra 25' to my power cord. If the extension cord is sized for the type plug ie: 10 gauge for 30 amp and 6 gauge for 50 amp- it will be fine in 99.5% of the applications. Beyond 25' more I might start thinking about gauge vs probable load.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41, 2021-49
Old 09-23-2020, 07:46 AM   #7
PhD, Common Sense
It sounds like you have asked yourself the questions. My concern is that most people seem to believe that, if you need more length, just add more cord. That is dangerous thinking.
Old 09-23-2020, 08:25 AM   #8
Canadian Member
eye95, I’m no electrician but I’ve learned that the wire gauge needs to suit the amperage you’ll be using and longer runs will cause voltage loss. Is there anything else that I should be aware of?
Most sites that have a 50A outlet on the pedestal will probably be within the reach of the factory-supplied power cord but I do have a single 25 ft.-long 50A extension cord and I have no concerns using the two cords on a 50A site since we only have one AC unit. We’ve been to several Provincial Park campgrounds where we needed at least 75 ft. of power cord to reach the 30A pedestal. In those situations I used the 50A factory-supplied cord, the 50A extension cord and then 1 or 2 30A extension cords as needed. I doubt I’m ever using close to the full 30A at those sites and, based on actual measurements, the wire gauge is sufficient to prevent much voltage loss.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 09-23-2020, 01:40 PM   #9
Our trailer is sometimes at our music festival location unattended. A couple years back I arrived to find my 25' 50 AMP cord missing. After much cursing and screaming it was determined that one of our volunteers had accidentally mowed it with the tractor! Ordered an OEM replacement from Amazon and was powered back up quickly. The only bright spot is that he hit it right in the middle. So now, after ordering the proper connectors from Amazon, I have two 10' 50 AMP extension cords. Haven't needed one yet but good to know they are down there if needed. Lemonade out of lemons!
2020.5 Cedar Creek Hathaway 34IK
2016 GMC Sierra 2500HD Denali Crew Cab Duramax
TXFolkie is offline   Reply With Quote
Old 09-23-2020, 02:38 PM   #10
Only once in 13+ years have I had to use the additional 25' extension cord....but I was glad I had it. I also carry two 30 amp cords just in case the c/g doesn't have 50amp service....and I have had to use one of them more than once.
With all that said, I carry both a 30A and 50A surge protector.
Mike K
2019 Cedar Creek 34RL2 w/disc brakes
2017 GMC 3500 D/A, DRW, 40Gal Aux Tank
USN 76-82
Retired Dept of Navy: Navy/USMC Flt Test Engineer
Splashes3 is offline   Reply With Quote
Old 09-23-2020, 08:06 PM   #11
Safe to have two
You would be just as safe with two AC units, since each of them is on a separate branch. That is, one is on the L1 terminal and one is on the L2 terminal. The maximum current on each conductor is the same.
(For the nitpickers in the crowd, it is indeed true that both AC units share the common neutral return, but the currents are out of phase and cancel each other out. If the two ACs consume the same amount of current, they contribute no current to the neutral.)
Larry
Larry-NC is offline   Reply With Quote
50 amp, power
