Old 10-18-2020, 03:11 PM   #1
LCI Electronic Leveling
Have a 2011 CC Touring Edition 36 RE
Question about the Lippert LCI level up system. A few times when trying to either extend or retract the jacks it would give me an error to much angle and not let me retract or extend one side.
Is there away to override that issue? I usually get it done somehow but usually takes me forever to get to do what I want it to do.
So is there a manual override or something else?
brucec is offline   Reply With Quote
Old 10-18-2020, 03:43 PM   #2
I don’t think you can override it. You just need to bring the low side up or the high side down to reduce the angle.
2016 Siverback 33IK, Towed 40K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
Old 10-18-2020, 04:12 PM   #3
Well I hooped up to the truck and hit auto retract that worked.
But my jacks were extended on one side only and I was trying to retract them and it would not let me kept saying to much angle. Guess maybe I could have tried extending the opposite side maybe that would have worked not sure.
Old 10-18-2020, 04:36 PM   #4
You might try “manual mode”. Press the up arrow until you see “manual mode” on display, then hit “enter” button. Not sure this will help because the system shuts down if one side gets more than 2-3 degrees higher or lower than the other side.
leveling
