Old 10-04-2018, 06:40 PM   #1
rracer5's Avatar
LCI hydraulics won't work
Hey friends......Not a Cedar Creek owner but, our friends are and here's the problem.
It's a 2015 CC Hathaway Edition 38FB. They bought it used and set it up on their lease lot. Since someone else delivered it and set it up, it's not exactly where they want it in relation to the existing deck so, we decided to get together and move it........nope! Suddenly none of the LCI hydraulic systems work...no leveler action, no slide action, nothing. He was told that the solonoid switch was bad. We put a new one in that now just clicks loudly but, still no hydraulic pump action. If I disconnect the secondary 12v power to the solonoid, I can hear a faint clicking from someplace else in the area of a solid state circuit panel. The battery shows 12.9 volts and when I click any function to raise or lower the levelers manually it only drops to 12.8 volts & I get/hear a quick clunk from one of the hydraulic levelers but absolutely no hint of any activity at the hydraulic pump. It seems that all slide, leveler and schwintec slide functions are semi-dead.
Any ideas/help/suggestions would be appreciated.
ID:	188252   Click image for larger version
ID:	188253   Click image for larger version
ID:	188254   Click image for larger version
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 10-04-2018, 06:47 PM   #2
Same thing happened to me turns out these circuit breakers were bad
bedelstein is offline   Reply With Quote
Old 10-04-2018, 06:48 PM   #3
Old 10-04-2018, 06:57 PM   #4
rracer5's Avatar
Thanks. I didn't see any resetable breakers but I forgot to mention I did check all the fuses I could find and made sure all electrical connections were tight.
Old 10-05-2018, 07:10 AM   #5
Witch Doctor's Avatar
Pull the plug on the back of the board, then plug it back in, also there is a breaker that is located on the wall, you will see a red Handel up if it's need resetting, hard to find trace the wires from the pump. If all else fails call Lippert, and send them those pictures, they will want to see your controls, had a problem lime yours found a power wire was disconnected some how, took a day for me to fine. You should have a switch to let the legs in front up and down only, does that work? If not it's a wire.
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-05-2018, 07:43 AM   #6
W5CI's Avatar
it sounds like your battery is dead
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
W5CI is offline   Reply With Quote
Old 10-05-2018, 08:11 AM   #7
First thing I would do is check the battery, the thing I would do is a hard reboot. The way you do that is first unplug from the power source and then take the negative cable off the battery. Leave the camper with no power for a minute and then connect the battery again. You should be able to run the jacks up on battery power alone. Another way to check the battery is try to bring the jack up and have someone inside the camper with the lights on. If the lights dim out itís probably a bad battery
spock123 is offline   Reply With Quote
Old 10-05-2018, 11:15 AM   #8
Type in 12 volt dc circuit breaker with manual reset. It will show you where reset buttons are on circuit breakers. They are hard to see sometimes because the way they are mounted. We had same problem and this took care of it.
stevenlerskine is offline   Reply With Quote
Old 10-05-2018, 11:24 AM   #9
NMWildcat's Avatar
Since you have checked battery and connections, it sure points to either a resettable fuse that needs resetting, or auto reset fuses that have failed. I would get out my multimeter and see where the power stops.
Good luck and let us know what you find.
Scott and Liz - Southern NM
Old 10-05-2018, 11:58 AM   #10
In your original post, the 3rd pic of the bussbar. Look very closely on the left hand side of it and you will find some very small resettable buttons. Make sure they are all set.
2016 Siverback 33IK, Towed 40K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
Old 10-05-2018, 12:00 PM   #11
In your 4th pic you ask if schwintec switch. I donít have a shwintec slide but I do have a switch like that and it runs the hydraulic slides...
Old 10-05-2018, 04:33 PM   #12
rracer5's Avatar
dalford...you nailed it!! What I thought was a simple bussbar was what you described. I found 2 circuit breakers tripped. All slides & hydraulics are working.
Yes it does. Thanks. Once I reset the above breakers, all is working again.
Old 10-05-2018, 06:44 PM   #13
Great, Iím glad it all worked out and thx for coming back to the forum and letting us know.
Old 10-05-2018, 08:09 PM   #14
Didn't the OP say he had 12.9 volts?
BigRockr is offline   Reply With Quote
Old 10-05-2018, 08:18 PM   #15
NMWildcat's Avatar
Didn't the OP say the problem has been resolved, so this point is now moot.... We really should be able to close threads we open.......
Old 10-05-2018, 08:19 PM   #16
What are you a moderator?
hydraulic
