Old 08-15-2018, 11:25 AM   #21
NMWildcat's Avatar
Originally Posted by CHICKDOE View Post
to nmwildcat: you have just made my day, if not my week! even with a tall ladder there is a portion of the front cap that i cannot reach to wax it. "lower the front legs as far as they will go to wax it". brilliant!
Glad I could help But I can't really take credit for it. I was standing on the very last usable step of a ladder to reach the top with a buffer. It made my wife nervous so she suggested I lower the front of the trailer. DUH!
Scott and Liz - Southern NM
Old 08-29-2018, 01:38 PM   #22
sh1pper's Avatar
Just for anyone that followed this post, I used my pin stabilizer (instead of my truck) to retract my jacks, then raised the front jacks to remove the stabilizer, then lowered the jacks so I could auto level the RV at a lower level with all the tires on the ground. The point being that the pin stabilizer will more than support the weight of the pin.
Hugh and Fran
"Riley" the dog
2018 Cedar Creek 38EL Champagne
2017 Ford F350 SRW CC SWB 4x2
Demco Hijacker Autoslide 18k Hitch
sh1pper is offline   Reply With Quote
Old 08-29-2018, 10:27 PM   #23
NMWildcat's Avatar
Braver man than I
Old 08-29-2018, 10:52 PM   #24
Blog: RVroadtripper.com
hbillsmith's Avatar
On level ground, I've run the LCI reset procedure many times while completely unhooked. You use manual mode to get each jack extended 6" to 8" (no more, no less). Then press and hold the retract button to have all Jack's start to retract. Once they start, let go of the retract button and they should all complete their up and this process clears any errors. The 5er will not fall and you can then drop front Jack's and level as usual.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
hbillsmith is offline   Reply With Quote
Old 08-30-2018, 09:03 AM   #25
sh1pper's Avatar
Not sure I understand? If you are unhooked and retract all jacks, what holds the pin up? Are you using a stabilizer?
Hugh and Fran
"Riley" the dog
Old 08-30-2018, 09:42 AM   #26
Indymule's Avatar
You would have to be on a serious incline for the pin to hit the ground. It's not going to tip over forward, the majority of the weight is still on the wheels. The front jacks will just be fully retracted lowering the nose. It's also going to happen slowly, the front jacks are not just going to drop suddenly.
Jay & Maria - Camp Dog Joplin
2018 Cedar Creek Champagne 38EL
Fulltimers since May 2018!
2017 Ford F350 Crewcab Dually Diesel
Officially homeless and loving it.
Ham Callsign K9NDY
Indymule is offline   Reply With Quote
Old 08-30-2018, 10:52 AM   #27
NMWildcat's Avatar
Exactly. I agree.
As mentioned previously, I've lowered my front jacks all the way so I can easily reach the top of the fiver while on a ladder to wax with a buffer. Of course the rear jacks were raised. Bottom front of the trailer (where the landing gear is) is probably 4"-5" off the ground and the king pin is several feet (3'?) off the ground. You would have to have a very strangely built fiver for the kingpin to have a possibility of hitting the ground.
Several posts have tried to explain this, and also given several safer options for re-leveling. Apparently all unsuccessful .
