Old 03-11-2018, 09:25 PM   #21
Originally Posted by FMcCue View Post
When the legs are down unscrew the cap from the bottle, it has a dip stick on it, make sure it is above the bottom notch.
Ok, will do that thanks!
Jokerbgood is offline   Reply With Quote
Old 03-11-2018, 10:22 PM   #22
If the Red (+) wire to your batteries is not firmly connected, it can result in intermittent power to your leveling system. This could result in failure of the leveling to perate as designed.
I hope this is your problem, cheap and easy to fix. If not, re-post and we so-called "experts" will try to figure out what could be wrong.
This is such a great web-site. I've learned the answers to questions that I have not even asked yet!!
Jakie-Boy is offline   Reply With Quote
Old 03-11-2018, 10:28 PM   #23
I agree itís a great web site and will keep you posted.
Thanks!
Old 03-11-2018, 11:04 PM   #24
I had the same problem last year. The hydrolic pump uses more amps than the factory installed fuse can handle. We increased the fuse to 8 amps insted of 4 amps.
Jdb95661 is offline   Reply With Quote
Old 03-11-2018, 11:26 PM   #25
I had this issues in cold. What fuse? Any issues since?
2017 Sierra 372LOK
2017 Ford F350 DRW
brian372lok is offline   Reply With Quote
Old 03-12-2018, 05:03 AM   #26
DouglasReid's Avatar
Originally Posted by NMWildcat View Post
Was it really tripping a 12v circuit breaker/resettable fuse, or was the control panel just turning off after reaching a pressure limit?
If it was on the 12v side, check your batteries for full charge.
If it was the control system, was it cold? Mine will reset several times when doing anything when it is cold and the hydraulic fluid is thick. I'm just too lazy to change the fluid.
There is a VERY easy way to change the fluid. A simple Harbor Freight tool:
https://www.harborfreight.com/pneuma...der-61912.html
It is a brake fluid bleeder costing $35. It will suck the hydraulic fluid from your reservoir and you can pour fresh back in. Do it with your slideouts and jacks retracted and there will be more fluid in the tank. Do it twice to completely flush the system with the new fluid. 10-20 minute job depending on how many times you do it.
Be sure to use Synthetic fluid and the problems with it thickening in cold weather will be GREATLY reduced.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is online now   Reply With Quote
Old 03-12-2018, 06:05 AM   #27
Filling a hydraulic reservoir when any cylinder is Extended can cause "Overfill Condition" when cylinders Retract! Youroo!!
Old 03-12-2018, 07:05 AM   #28
Which is why I said to have the slideouts and jacks RETRACTED!
Old 03-12-2018, 07:09 AM   #29
I was replying to "FMcCUE"! as Posted! Youroo!!
