Old 10-12-2020, 10:43 AM   #21
Originally Posted by LittleBill View Post
What ball valves did you use? Do you have a link for them?
These are the ones I used: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
I've had them for a couple of years now. Seem to do the job.
2018 Flagstaff Micro Light 21DS
2018 Ford F250
bergy is offline   Reply With Quote
Old 10-12-2020, 02:58 PM   #22
LittleBill's Avatar
Thanks for the feedback.
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2021 Chevy 3500HD Crew Cab 4X4 DRW Duramax (replaced 2015 Chevy 2500HD Crew Cab 4X4 Duramax)
Curt A25 5th Wheel Hitch (replaced Demco 18K Auto-slide)
LittleBill is offline   Reply With Quote
Old 10-12-2020, 03:55 PM   #23
What ball valves did you use? Do you have a link for them? Thanks.
Does anyone know off hand (mine is in storage) what size thread the plug is that screws in?
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I cut off the fitting and went direct to the PEX.
2018 Chevy 3500 Crew Cab, 4WD Duramax
2019 Cedar Creek Silverback 33ik
Jim in Florida is offline   Reply With Quote
Old 11-22-2020, 05:38 AM   #24
Hi Jim. Can you take a pic please? My line broke when I had a blow out, and I'm trying to repair it. I want to make sure I get to to look like it was previously. Thanks!
coachmen916 is offline   Reply With Quote
Old 11-22-2020, 06:42 PM   #25
See attached photo.
Old 11-23-2020, 12:47 AM   #26
Excellent. Much appreciated!!!
Old 11-23-2020, 04:50 AM   #27
dbledan's Avatar
Those screw on caps stink. Always crack....cut the pex off clean where it broke and get a sharkbite 1/4 turn ball valve with a 3/4 hose connection.
https://www.lowes.com/pd/SharkBite-B...E&gclsrc=aw.ds
It will be easy to hook up a hose and use it and simple to fix amd more flexible for future needs.
You may need to measure the pipe to see if it is 1/2 or 1/4in.
dbledan is offline   Reply With Quote
Old 11-23-2020, 02:28 PM   #28
I bought these off of Amazon. I think they were $9 a piece.
Mueller-Industries-102-353HN-HOSE-2-Inch. I like the fact I can hook a garden hose up to them. Very easy to install.
Mike K
2019 Cedar Creek 34RL2 w/disc brakes
2017 GMC 3500 D/A, DRW, 40Gal Aux Tank
USN 76-82
Retired Dept of Navy: Navy/USMC Flt Test Engineer
Splashes3 is offline   Reply With Quote
drain
