Old 08-13-2020, 09:24 AM   #1
Low point drains
Today I installed a pair of ball valves on the hot and cold low point drains located near the entry door on the curb side. It will be easier and more reliable than unscrewing the pipe plug when I need to drain the lines.
I noticed on the street side of the unit, just behind the tires, another blue pex line with a plug. Does anyone have an idea what that drain is for? I'll likely put another ball valve on that.
What about draining the water heater? I'm surprised that the only way to drain that is to remove the anode rod. Is there a valve available that contains and anode rod? I see them on Amazon for Atwood heaters.
Jim
2019 33IK
2018 Chevy 3500 Crew Cab, 4WD Duramax
2019 Cedar Creek Silverback 33ik
Jim in Florida is offline   Reply With Quote
Old 08-13-2020, 09:34 AM   #2
Jim
2019 33IK
Yep, lots of folks get tired of removing the caps/plugs from the low point drains and install valves. I put valves with garden hose ends on so I can use them as an additional connection if necessary.
The other blue line might be the fresh tank drain or overflow. (the overflow typically wouldn't be capped unless someone had an issue with the fresh tank siphoning empty while traveling) Can't say for sure? Did your dealer go over those things with you?
As for draining the water heater... if you have an anode, you have a Suburban WH and they do make an anode with a petcock on the end. There have been some negative reports on its use as the tank doesn't drain as completely as removing the anode and you lose a little bit of anode material. I never drain my WH once filled in the spring, until it's time to winterize. (or my low point drains)
If you do decide to regularly drain from your low point drains, be sure to put the WH in bypass before draining so any buildup in the WH doesn't get sucked back into the plumbing when draining at the low point drains.
Days Camped: '18=51 '19=58 '20=110 '21=94
Old 08-13-2020, 09:35 AM   #3
only thing i can think of would be fresh water tank drain. the fresh water overflow would not have a plug on it.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is online now   Reply With Quote
Old 08-13-2020, 10:11 AM   #4
Not the overflow, it is uncapped.
Not the drain, dealer had shown me that one two years ago and I've used it.
It is in the slide section, so my only other thought would be a drain for the ice maker line. I'll have to look a the ice maker line and see if it looks feasible.
Jim
Old 08-13-2020, 11:14 AM   #5
but a drain wouldn't have a cap on it, would it?
Old 08-13-2020, 11:17 AM   #6
You need to pull the anode rod every once in a while. White flakey scale needs to come out. Keeps faucets clear. and tank from premature failure. I put a piece of plastic tubing on my shop vac ,,via duct tape and suck out the flakes. A dab of antisieze on top of teflon tape on rod threads , and its a 5 minute job.
Thomas ho is offline   Reply With Quote
Old 08-13-2020, 11:45 AM   #7
Originally Posted by Thomas ho View Post
You need to pull the anode rod every once in a while. White flakey scale needs to come out. Keeps faucets clear, pump diagrams from getting chewed up. and tank from premature failure. I put a piece of plastic tubing on my shop vac ,,via duct tape and suck out the flakes. A dab of antisieze on top of teflon tape on rod threads , and its a 5 minute job.
How would it affect the pump diaphragm? The water heater should be on the outlet side of the water pump with both a check valve and filter in between the pump and water heater (on standard setups). Low point drains are also on the discharge side of the pump, so even when draining, it does not get sucked through the water pump.
NavyLCDR is offline   Reply With Quote
Old 08-13-2020, 12:09 PM   #8
Well, living in south Florida, I really don't have to worry about it, but if the ice maker line had water in it and it froze, that would be bad. That is why I think it would/should have the ability for it to be drained.
Old 08-13-2020, 12:21 PM   #9
Could it be for winterizing the system? My antifreeze suction line is near my low loint drains, which is directly under the water pump location.
2020 GMC Denali 4X4 2500HD Duramax
2018 Work & Play 25WAB
sdelam is offline   Reply With Quote
Old 08-14-2020, 09:53 AM   #10
It wouldn't. You are absolutely correct.
I also cringe when I see folks mention putting 'antisieze' on the anode threads of potable water. Unless you use "food grade" antisieze, (which wasn't mentioned) many of them have toxic chemicals in their composition that I'd want nowhere near my water.
Old 08-14-2020, 09:59 AM   #11
Jim
Could be the icemaker drain or a drain for the refrigerator itself. Our refrigerator automatically defrosts itself and there is a line for the excess water to drain out of the bottom.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 08-14-2020, 12:14 PM   #12
Jim
Again, to point out for clarity... the OP says they know it is NOT the fresh tank overflow, it is NOT the fresh tank drain and as everyone has mentioned, if it is a drain for the ice maker or condensate from the refrigerator, it wouldn't be plugged. (which the OP has said it is)
It will be interesting to see what this plugged 'drain' in the slide-out really is.
What is above it inside the slide?
Old 08-14-2020, 07:21 PM   #13
On my 2018 34RL2 that is a third low point drain. You need a way to drain the water line to the ice maker, that's it.
cub22908 is offline   Reply With Quote
Old 08-14-2020, 11:25 PM   #14
Please reread post #4 again, the op says that it's UNplugged. That's why it's possible to be a refrigerator drain. Ours only drips when the refrigerator defrosts itself.
Old 08-14-2020, 11:33 PM   #15
LittleBill's Avatar
Jim
Yes, I am almost positive like you are thinking, it is a drain to aid in draining the fridge ice maker. Also there should be a push-pull valve to by-pass the ice maker if you are not using it. Thus you don't have to winterize/de-winterize your fridge.
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2021 Chevy 3500HD Crew Cab 4X4 DRW Duramax (replaced 2015 Chevy 2500HD Crew Cab 4X4 Duramax)
Curt A25 5th Wheel Hitch (replaced Demco 18K Auto-slide)
LittleBill is offline   Reply With Quote
Old 08-15-2020, 04:28 AM   #16
I said in post #4 that 'Not the overflow, it is uncapped.' meaning that the fresh water tank overflow is not capped.
This 'unkown' blue pex line with a cap on it is likely the icemaker supply line drain.
Thanks for all of the input. If I find it to be anything other than that, I'll let you know.
Jim
Old 08-15-2020, 06:58 AM   #17
Jim
Well... I guess I can read after all.
If you find out for sure, please let us know.
Old 08-16-2020, 07:00 PM   #18
Sorry. Guess I can't read.
If it's got a cap on it, you should be able to put a ball valve on it. Tis a puzzle. I wonder if it's a second low point drain for that island sink. Perhaps it was easier to run a second drain for the island faucets than run it to the bathroom drain.
Old 09-02-2020, 12:06 AM   #19
Chillaxin's Avatar
We have an early 2020 34IK. Our low point drains screw in 'plugs' started leaking out of the blue, so the dealer replaced them under warranty with valves. Stupid of CC to just use screw in plugs to begin with.
The blue pex line is the drain for the fresh water tank. Ours has a valve on that one.
2015 F350 6.7L SD Lariat 4x4 Crew
2020 CC 34IK w/ dishwasher & TrailAir
2014 21’ Thunder Jet Luxor OB 150 Yamaha & 9.9 kicker
“Hunt, fish, camp, travel, repeat”
Chillaxin is offline   Reply With Quote
Old 10-11-2020, 11:28 PM   #20
LittleBill's Avatar
What ball valves did you use? Do you have a link for them? Thanks.
Does anyone know off hand (mine is in storage) what size thread the plug is that screws in?
drain
