03-31-2015, 01:56 PM
#81
I think I read somewhere that a st tire, special propose tire, was designed to run 65 mph and should stay around 63, LT tires are designed to run much faster. Just something to think about. I saw something on the web today that big trucks were going to fast for the tires they were riding on, there's were only supposed to run at 65 mph, I think someone forgot to tell them. My TST TPMS will let me know when the temperature inside the tire starts to rise, I try to stay around 64 and I get passed a lot and by a lot of campers too
03-31-2015, 03:31 PM
#82
LTs are all fine & dandy but no reputable dealer in my area will sell them or install them on a trailer.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
03-31-2015, 03:45 PM
#83
It's my understanding rims for trailers specify ST tires only. I could be wrong but I think that's why the g614's are so expensive because they are built differently compared to LT tires. Trailer tires need to
Be able to handle high psi ratings and the sidewalls to resist the twisting from turning unlike LT tires which don't face the same twisting from the tandom axels. I am no expert on tires but that's my limited understanding.
03-31-2015, 06:57 PM
#84
It was stamped on my 30RL how much pressure the rims would take, so from what I understand when you go to LT tires you have to change rims too
04-01-2015, 04:50 AM
#85
So why would anyone take on the liability of changing to LT tires & changing rims ???????
1966 Mustang GT
1986 Mustang SVO
04-01-2015, 05:48 AM
#86
I don't think there is a liability problem if you change the rims when you change the tire and yet you yyo
04-01-2015, 05:59 AM
#87
Messed up a little there, if you change the rims when you put on the LT tires there is no liability problem otherwise how did I get the Goodyears on my camper from the factory. I think the st tires are good tires if made right, for me I will not buy tires made in china. I sometimes drive over 70, maybe 75 and the st tires are only made for 65 or less
04-01-2015, 07:51 AM
#88
GY 614's are rated for 70 MPH
04-01-2015, 09:45 AM
#89
You must be looking someplace I am not looking because what I see is the G614 are speed rated at r which is 106 mph but you have to have a special rim for these tires. Rims that can take the high pressure and high pressure vale stems. They will not work on st rims, my st rims said 80 lbs max. There is a warning on the tires about this plus it says not to mount on 16.5 inch rims. But Walmart sells this tire, they are not cheap tires but I know that if I want to run a little fast then I can, with the st tire I am taking a chance.
04-01-2015, 02:29 PM
#91
What size tires did you go with and how much spacing between the tires from the original ones??
05-11-2015, 07:39 PM
#92
Well I ended up buying a new set of Goodyear marathons. The only thing is I switched from 235/85/16 to 235 /80 15.
After I get them installed I'm ready
haven a blast
05-11-2015, 07:44 PM
#93
So you went with both tires and wheels, alloy wheels with metal valve stems?
05-11-2015, 07:49 PM
#94
What ever came on my 5th wheel that should have said 235/80/16
haven a blast
05-11-2015, 07:53 PM
#95
You are planning on using the stock wheels with the new tires you got?
Unless there is a typo you have 16 inch now and you bought 15 inch tires.
15 inch tires on 16 inch wheels will not work out well.
05-11-2015, 07:57 PM
#96
It was a typo. The original rims are 16 and the tires that i bought are 16.
haven a blast
05-11-2015, 07:59 PM
#97
Ah!
I was worried there for a bit..
Travel safe.
05-11-2015, 08:04 PM
#98
Originally Posted by Ford Idaho
Ah!
Travel safe.
Thanks.
I'm going to take it for a good haul this weekend and make sure all is good.
haven a blast
05-12-2015, 09:12 PM
#99
Commercial Member
Another typo ? or ???
LT235/80R16 have a lower load capacity than LT235/85R16 unless you go up in Load Range such as LR-D to LR-E
COuld you please clarify by providing the complete size info of before & after?
Note by "Complete": I mean letter prefix + numeric dimensions + Load Range
Just too many variations possible for this information to be of help to others if we have to guess.
Thanks in advance
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
05-13-2015, 05:28 AM
#100
the tires i got new are 235/80/16 load range is E
the tiers that came on the trailer are 235/85/16
haven a blast
