Old 01-31-2019, 04:36 PM   #101
Mr. Dan's Avatar
Originally Posted by itat View Post
Thanks. I missed where you said that in Post #34.
Thanks also doc73 and Mr. Dan. I haven't had an opportunity to use them yet so I wasn't sure if they have a non-slip surface that's hard to clean.
itat, here’s a pic of my step treads — fairly simple to clean.
And here is a pic of the handrail which my height-challenged DW can reach from the ground. This is really important to her due to her back problems and occasional vertigo.
And here’s a pic of where the unit sits when it’s not on a trip. I’m fortunate not to have to jam it in a lot which is packed like sardines.
Old 01-31-2019, 05:54 PM   #102
Who Dares, Wins
doc73's Avatar
Originally Posted by Mr. Dan View Post
Same here (well... not snow) and have no issues. We always keep a mat in front of the door regardless of step position.
Hopefully no snow in TX...
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 01-31-2019, 06:06 PM   #103
Mr. Dan's Avatar
We had a mere dusting 12 days ago.
BTW, Texas is not like the Great Sahara! I made these pics on our property a few years ago... and I have pics of a 5.5" layer of ice/snow/sleet on our metal roof. It took 10 or so days to melt off.
Name:	House from north property line.jpg
ID:	195799   Click image for larger version
Name:	House from Road.jpg
ID:	195800   Click image for larger version
Name:	Marty at back corner.jpg
Old 01-31-2019, 06:48 PM   #104
Retired JSO's Avatar
MORryde Steps
Originally Posted by acvp1 View Post
They ARE sturdy.....but........
we store our 36CK2 in a heated 15 x 50 garage. We cannot access our RV when stored because these steps swing out so far they hit the wall! I must pull RV outside to gain entry.
WHAT A PITA !!!!!!!!!!
15’ wide is plenty of room to deploy these steps if you don’t deploy the opposing slide .
Retired JSO is offline   Reply With Quote
Old 01-31-2019, 09:07 PM   #105
Denver To Yuma In 90 Days
Too many if's for me...
JohnD10 is offline   Reply With Quote
Old 02-02-2019, 06:42 PM   #106
Daycruiser's Avatar
I wonder if Cedar Creek will build a Hathaway using the pull out steps, I'd guess the frame still has the mounting brackets for the box?
Retired 2020.
46 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
Daycruiser is offline   Reply With Quote
Old 02-02-2019, 10:18 PM   #107
Engineer of Crazy Train
ChooChooMan74's Avatar
Well, this thread gave me some awesome tips. At the show, I personally like these. Time will tell when we get the and try them out on our new unit.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 03-03-2019, 12:13 AM   #108
B and B's Avatar
One of the must haves was these MORryde steps when we purchased our new Landmark. In tight spaces an issue but roadside stops can be worked around with finding the right place to stop.
Old 03-03-2019, 06:19 AM   #109
Papadave's Avatar
I have a wolf pup that came with the step above steps. The bolt spacing is 38” rather than 25” for the coach mount to the outriggers. This precludes a quick bolt on of under mount steps. I bought undermount steps and lippert outriggers from etrailer but still need to weld up a t bracket to reach the coach mount bolts. Soooo I put the step above back in! Still hatin em but I will post some modifications that may help. One biggie is proper install. Mine was botched at the factory. Here is a video by the manufacturer. It is interesting that when he tries to close the door after the install it pops back at him. Ideally they would design a door and stair combo that does not warp the door.
Papadave is offline   Reply With Quote
Old 03-03-2019, 08:39 AM   #110
Although I have made mine detachable for emergency situations, I think Morryde should investigate a system similar to attic access ladders that are commonly used in home garages. Basically having a single knee joint. That would allow access in situations when you're too close.
2018 Chevy 3500 Crew Cab, 4WD Duramax
2019 Cedar Creek Silverback 33ik
Jim in Florida is offline   Reply With Quote
Old 03-04-2019, 08:04 AM   #111
How did you make them detachable??
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 03-04-2019, 10:26 AM   #112
dalspot's Avatar
I saw on RV Business recently that 3 of the RV manufacturers were going to start installing the Torklift steps But the 3 were not named.
https://www.rvbusiness.com/blog/tork...up-at-rvx.html
2017 Cedar Creek 34RL2
2014 Ford F-350
dalspot is offline   Reply With Quote
Old 03-04-2019, 03:59 PM   #113
See post #31 in this thread.
Old 03-04-2019, 07:24 PM   #114
Sorry. I joined this post late. X2 on no help from MORyde. Any chance you can post a pic. I'm a little nervous about drilling out anything on a brand new 5th wheel.
Cathy & Jeff
Midland, Michigan
Old 03-04-2019, 08:30 PM   #115
I won't be able to get photos until next week.
Old 03-04-2019, 08:38 PM   #116
That works great. I'm ordering the new 5th wheel tomorrow and I just found out that the step above is the only option on my floor plan. I have about a 2 in wide parking window if I want to be able to open the steps at the house.
Cathy & Jeff
Midland, Michigan
Old 03-07-2019, 05:23 AM   #117
Daycruiser's Avatar
I have found out since my earlier post that Cedar Creek will substitute the Pull Out style steps if the floor plan will accommodate it, Unfortunately my 34IK will not accommodate the pull out box required due to the door placement too close to the wheel well. I'm stuck with the tip out style, oh well, the dog will appreciate them.
Retired 2020.
Old 03-07-2019, 09:20 AM   #118
X2...I also confirmed this when I ordered my 34IK. In fact..the MORyde Steps are what made he 34IK floorplan possible. I plan on making them "easily removable" for those tight situations.
Cathy & Jeff
Midland, Michigan
Old 03-08-2019, 11:53 AM   #119
Torklifts stick out just as far. Only thing different is deployment.
goduc is offline   Reply With Quote
Old 03-08-2019, 12:00 PM   #120
Yes...
But they can be deployed at many different angles!
Not just in...or out!
