11-25-2022, 04:12 PM
need help with converter
can any one help with the location of the converter i n a 38 fbd , thanks it's a cedar creek
11-25-2022, 04:22 PM
Do you happen to know the year?
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 135; Booked for 2023 = 28
11-25-2022, 06:55 PM
It should in the "basement area. Not sure exactly where yours is but its normally behind a cabinet or access panel
11-26-2022, 05:28 PM
sorry , it's a 2019
11-26-2022, 05:35 PM
The converter in my 2015 Wildcat is not in the basement but is behind a door similar to the one pictured. Mine's under a set of closet doors facing my kitchen... and just above floor level.
11-26-2022, 06:47 PM
somewhere around 8:30 in the video but there not always in the same place. Almost always close to the fuse/breaker panel. Mine is in the bottom of my breaker panel
11-27-2022, 10:05 PM
CCRVOC
converter location
My 2017 38fb2 has the converter behind the fuse/breaker box. It's beside the bed and then under the shower seat. Bad location if you ask me.
2017 Cedar Creek 38FB2
2019 Chevy 3500 CC LB DRW
B&W Companion
11-28-2022, 11:03 AM
I'm finding in my research that many of the Cedar Creek's CONverters are located BEHIND the interior Power Distribution Box (breaker box) as mentioned by Mr. Dan in post #5.
Many are accessed by removing a panel in the front pass through compartment(basement) or a panel inside near the bed or kitchen cabinet.
Days Camped: '18=48 ☼ '19=58 ☼ '20=110 ☼ '21=116 ☼ '22=112 ☼ '23=32
11-28-2022, 11:26 AM
Converters are typically integrated into the power center. So much so that this panel is commonly referred to as The Converter. There's a breaker marked CONV in my power center. The converter itself is a black box buried inside the center accessible when the power center is removed for sure and maybe if the face panel is removed.
-- Chuck
11-28-2022, 12:59 PM
In my 2019 341K it is located behind fuse/circuit breaker panel. To get to mine, I have to go to basement pass-through. Mine has InCommand system and there is a black box in the basement that has all of the connections to it. To the right of that is a fiberboard cover that is removed with about 6 screws and then you can see it through the opening. If you have a small enough frame, you can get through that small opening to actually touch it or work with it. On mine, it is plugged into an outlet on the back of the circuit breaker panel.
2019 Cedar Creek 341K
2016 Ram 2500 Cummins
11-28-2022, 03:28 PM
Ive never seen a convertor that plugs in. Inverter yes
11-28-2022, 03:31 PM
Many deck mount converters do plug into an outlet.
https://parts.unitedrv.com/products/...YaAvtdEALw_wcB
 2011 Flagstaff 831 RLBSS
I'm trying to write a self-help book but I'm struggling. Any advice?
11-28-2022, 03:51 PM
I have a 2020 model year Cedar Creek Champagne 38EFK, my converter is also plugged in, in fact it plugs into a power socket on the rear of the power centre. The actual converter is located behind the fireplace beneath the TV set.
11-29-2022, 06:56 PM
Originally Posted by wmtire
I learned something, always happy to learn. Might come in handy in the future. Thanks
12-06-2022, 02:15 AM
Ours was behind the slide out waste basket.
Dan/n9hqg
12-06-2022, 02:30 PM
thanks every body i found it . thanks for your help
12-06-2022, 02:49 PM
It might help other CC owners if you stated where you found it.
12-06-2022, 03:07 PM
I once owned a 2011 36re and as I remember it was behind the fuse panel.
Dan/n9hqg
12-06-2022, 03:53 PM
Please see post # 16. Now we're waiting for him to tell us where he found it!
12-06-2022, 05:08 PM
Of course I saw it!!! We all should know where it is. It's the access point we need and there could be more than one.
Dan/n9hqg
