Originally Posted by tomkatb
On my 2018 we had the same issue. The hdmi arc cable was not plugged in.
They like to run only one arc hdmi between the DVD player and tv. Arc sort of means audio visual moving in either direction. Otherwise the hdmi cable is one way.
Has to be plugged into two arc outlets. Both components.
You are going to need to see the connections likely. Any goofy wire setup is possible.
Get the drawings of the components connections from the Manuel.
??????? Just because they invented ARC means that the DVD HDMI cable plugged into the TV's HDMI input doesnt send the Audio there as well.
ARC is really for sending the Audio to a Remote Audio Receiver and also to turn that device on and to use it for volume control. An application would look like this , Audio and video out of say a BlueRay into the TV and then the audio out to the home theater system.
In this case if the DVD was playing all you have to do is to use the standard HDMI input to the TV and the TV gets both audio and video and it is done. The question remains is if the DVD player can strip away the audio and send it to the speakers or if it requires a ARC cable from the TV to get the audio from the speakers. Original post said he can hear the Audio from the DVD therefore only the video needs to be sent to the TV and it is done so ARC shouldn't enter into this.
