Old 07-20-2021, 01:51 PM   #1
No power to A/C
My Cedar Creek 34RL2 has been in storage for almost two years. We have been kind of under the weather. Decided to take it out and go on a short trip. I made an appointment to put new tires on and re-pack wheel bearings. Almost everything worked except the air conditioner and fantastic fan. They are dead. Does anyone have an idea where to start troubleshooting? Thanks
dwebster is offline   Reply With Quote
Old 07-20-2021, 02:13 PM   #2
Isn’t the fantastic fan 12 volt and AC 120? I would start with the obvious, the power center. Breaker for AC and fuse for fan.
Capacitor is online now   Reply With Quote
Old 07-20-2021, 02:14 PM   #3
The fantastic fan runs on 12 volts DC and the Air Conditioner runs on 120 Volts AC, so they are most likely unrelated. Have you checked breakers for the AC?
Does the Fantastic fan make any noise? It uses a current sensor system to shut off the lid motor when it is fully closed or open. Sometimes, the lid will stick to the sealing gasket. You may have to climb on the roof and help it as someone turns it on.
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 07-20-2021, 02:22 PM   #4
That is true but the air conditioning control is 12v to a relay.
Old 07-20-2021, 02:27 PM   #5
wmtire's Avatar
True. The thermostat is 12 volt DC.
2011 Flagstaff 831 RLBSS
Old 07-20-2021, 02:44 PM   #6
Mr. Dan's Avatar
One of my friends had this problem. I tested his battery and it was bad. He put in a new battery and his A/C woke up.
Old 07-20-2021, 02:57 PM   #7
Thanks for reply. I checked the batteries with a meter (13.2v). I checked the A/C breakers. Can find no fuse for Fantastic Fan. I am missing something somewhere.
Old 07-20-2021, 03:38 PM   #8
Is the fan in the bathroom? If so does the light work? For 120 volt, do all receptacles work?
Old 07-20-2021, 03:44 PM   #9
Start with the basics...
Do you have 12v power at the Fantastic Fan or the wall control if so equipped?
Do you have 12v at the A/C thermostat?
Do you have 120v at the A/C unit?
We can all make some guesses but until you do some basic electrical checks they are just that, guesses.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 07-20-2021, 04:35 PM   #10
Oops! You're right.
Old 07-21-2021, 02:31 PM   #11
Newbie Level 2
No AC Fixed
My Coleman 8330-3862 digital thermostat was dead. Hence, no AC no system fan, nothing was working with the heat-cooling. Took off thermostat and checked to make sure all wires were tight and coming in the back. When I took off the front cover to the Thermostat, there was a 2 amp glass fuse about 1 1/4" long. It looked ok but I decided to check with my meter. Turns out it was no good. I found a replacement, 2 amp, at my local auto parts store and replaced it. ALL is now working. I have no idea why this blew? but has been ok for a few weeks now. Hope this helps?
KeepTravelin is offline   Reply With Quote
Old 07-21-2021, 02:49 PM   #12
Bob2019's Avatar
No need to climb on the roof to get the lid unstuck. Just twist the 4 screen holders and remove the round screen. Then push up on the lid underneath with some kitchen handle tool and turn the manual twist knob. It will then pop off the sealing gasket.
2019 Forester 2861DS
Bob2019 is offline   Reply With Quote
Old 07-21-2021, 03:01 PM   #13
I know all of my Maxxair fans have this option but none of my Fan-tastic fans did. Have they changed the interior trim/screen?
Old 07-21-2021, 03:07 PM   #14
I didn't know that, but then, mine is so high up that I can't reach it. The one time it happened to me, I just climbed up the ladder on the back of the 5er. I'll have to check that out because I'm sure mine could use a good cleaning.
Old 07-21-2021, 03:19 PM   #15
BillyBass's Avatar
on the fan maybe the switch is sticking or went bad
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
BillyBass is offline   Reply With Quote
Old 07-21-2021, 03:34 PM   #16
Bob2019's Avatar
Suggestion for cleaning: This following can be done inside if you can reach your fan. Remove the fan blades and screen and clean. With a rag, wipe the underside of the vent cover and anything else looking dirty. Apply some slide lubricant on gasket, Next I pulled the armature out of the motor and wipe ends and add a few drops of oil and reassemble. Did that 2 years ago and everything works like new and very quiet. You can't do all this up on the roof.
Old 07-21-2021, 06:46 PM   #17
Iwannacamp's Avatar
Any glowing lights on your 12VDC fuses in electrical service panel?
2017 Puma 297RLSS
Old 07-26-2021, 09:33 PM   #18
I had to take unit to RV service for new tires and bearings. While it was thereI had them check “ no power to a/c and fantastic fan”. They found wires chewed by rodents. They fixed a/c but not fan. ( later )
Thank you to all who suggested things that I could try.
Old 07-27-2021, 09:13 AM   #19
Trailer Park Supervisor
NJKris's Avatar
Thanks for coming back and letting us know! Darn animals! I've paid thousands throughout years repairing rodent wiring damage. Ground hogs are my problem, anything they can reach from ground is fair game, they seem to love wires for some reason. And no matter how many I snipe, they keep coming back!
Yes, I drink the water!
NJKris is online now   Reply With Quote
Old 07-27-2021, 09:19 AM   #20
nomad297's Avatar
Cheap Chinese soy-based plastic-covered wire. A tasty treat for rodents.
Bruce
no power, power
