Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 09-17-2021, 09:31 AM   #1
no power to slides, where's the fuse?
"It was working when I parked it!" lol Re: a 36CKTS 5th wheel hooked up to shore power, there is no power to the slides, or the awning. Can anyone tell me where to find the fuse? or the reset button? or whatever I need to look for? My weekend adventure is in jeopardy!
bkearney is offline   Reply With Quote
Old 09-18-2021, 08:29 AM   #2
SeaDog's Avatar
check in the battery area along the frame for a resettable fuse on the heavy wire leading to the slides.
Retired Navy
2016 Flagstaff 26 FKWS
Old 09-18-2021, 08:36 AM   #3
NMWildcat's Avatar
Look for one of these and push the little black button. Usually in the proximity of the batteries in the basement or wherever the rats nest of wires is
Scott and Liz - Southern NM
Old 09-18-2021, 03:12 PM   #4
Otegoans's Avatar
I had the same problem with my 2015 29RE. I pulled the fuses (on mine two 20 AMP) cleaned the contacts and reinstalled them. Problem solved. On my 29RE the fuse panel is at the base of the stairs. Hope this helps.
Otegoans
Ken and Wendy
'15 silverback 29RE
'13 GMC 2500HD
Duramax/Allison
Otegoans is offline   Reply With Quote
Old 09-18-2021, 04:11 PM   #5
Your slides are hydraulic I assume. Check,the resettable breakers for the hydraulic motor. In the front basement behind the plastic cover against firewall. See pics below..
Im pointing to the small reset buttons on side of brear
ID:	263008   Click image for larger version
ID:	263009   Click image for larger version
2016 Siverback 33IK, Towed 50K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
Old 09-19-2021, 01:22 PM   #6
On my TT its along the frame behind the battery. Just a normal automotive fuse.
wjrdmr is offline   Reply With Quote
Old 09-19-2021, 01:40 PM   #7
NMWildcat's Avatar
OP has a fifth wheel which typically has the batteries in the basement so most fuses, resettable, or auto reset, are there also. No need to run them outside on the frame.
Old 09-19-2021, 01:53 PM   #8
2009 F450 2015 Cardinal
Our 2015 Cardinal 3875FB had that issue that was resolved by resetting the knife breakers near the hydraulics in the front compartment. It is black on black, so a flashlight is helpful in locating it.
AntonJ is offline   Reply With Quote
Old 09-19-2021, 03:04 PM   #9
CC fuses
Dalford is exactly correct. Great pictures! A head lamp is helpful as it hard to see in the front storage area. Also check the electrical cables to your pump and tighten. These are the 1/4 battery posts on the solenoid. When they get loose, it trips the breakers. If that fails, you can try a jumper on the solenoid.
Tundra 2014 is offline   Reply With Quote
Old 09-19-2021, 08:19 PM   #10
Herk7769's Avatar
If this becomes a nuisance, replace the fuse with a thermal automatic reset one. Had this problem on my first 5th wheel's landing gear and living room slides.
Make sure you use the same amperage though...
https://www.amazon.com/Gloaso-Automa...2&sr=8-10&th=1
Or you can use a manual one:
https://www.amazon.com/Tocas-Manual-...%2C162&sr=8-32
HAM CALLSIGN - KC3FFW
Old 09-22-2021, 08:43 AM   #11
Post #5 nailed it for my Cedar Creek 5th wheel. The top picture is rotated 90 degrees though.
Grumpy7159 is offline   Reply With Quote
fuse, no power, power, slide, slides
