Old 12-31-2017, 06:20 PM   #1
Boatdude62's Avatar
Open slides in cold weather
Getting ready to head south to warm weather. With temperatures in the single digits here, Iím nervous about opening the slides in cold weather to pack. Should I be worried? We have toppers on all slides.
Boatdude62 is offline   Reply With Quote
Old 12-31-2017, 06:30 PM   #2
No worries
If not camping, I am Sailing
JohnVtx is offline   Reply With Quote
Old 12-31-2017, 06:48 PM   #3
Brother Les's Avatar
unless the rubber seals are frozen to the sidewalls. I have two slides.... one worked fine... the other frozen solid and would not move.
Brother Les
Brother Les is online now   Reply With Quote
Old 12-31-2017, 07:15 PM   #4
Cyber Phrenologist
Radio's Avatar
Your problem is not cold.
Your problem is cold AND moisture. If there has been no precipitation in awhile you should be good.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 01-01-2018, 10:28 AM   #5
Turn heater on if slide is frozen, then open to load
bajamike1 is offline   Reply With Quote
Old 01-01-2018, 01:11 PM   #6
I’m doing the same thing leaving Pennsylvania Friday packing today going to leave heat on to keep things from freezing
dustycreek2 is offline   Reply With Quote
Old 01-01-2018, 10:31 PM   #7
Wingdreamer's Avatar
I opened my slide in mid winter and it tore the heck out of the rubber seal. I spray them down with silicone spray all the time. Made no difference. Now, I won't open it without being certain that it's not frozen or stuck.
2015 Forest River Vibe 268RKS being pulled by a 2010 F150 Lariat 5.4l, 3.73 axle Super Cab, Max Tow with 11,300 lb tow capacity , Equalizer 4 point W/D hitch
Wingdreamer is offline   Reply With Quote
Old 01-01-2018, 10:46 PM   #8
My single slide was frozen on one side. Ran the furnace for a day to load up, then it worked fine.
Bnrc73 is offline   Reply With Quote
Old 01-05-2018, 08:34 PM   #9
97flhtcui's Avatar
If you have metal weather shields on your slide toppers be careful of ice on them. They may not seat property around the topper tubes.
2019 Ford F-250 6.2l gas 430 E Lock
2015 Cedar Creek 34RL
MORryde IS 7000 LB
Kodiak Disc Brakes
97flhtcui is offline   Reply With Quote
slide
